Go to Post Yes, the real world is like that. Let's operate on a higher plane. - Taylor [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 18-01-2008, 11:31
neha neha is offline
neha is an unknown quantity at this point
Atmega32 port c pins
my team has designed a programmer for atmega32. all ports can be programmed successfully however pins 2,3,4,5(starting with 0) of portc cannot be programmed. we wrote a flash led programmer however these mentioned pins do not show any variation. they are showing a constant high. pls help us at the earliest.. thanks
using all port pins AMIRAM Programming 4 23-01-2006 00:52
pic: Pins Pins and more pins CD47-Bot Extra Discussion 26 04-09-2005 23:07
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
TTL pins Dave... Control System 3 07-02-2004 23:59
Drill Motors: Pins IN or Pins OUT Caleb Fulton Motors 28 03-02-2003 14:19
