Go to Post In FIRST, you can either have comfortable safety margins or you can have a competitive robot, you can't have both. - Joe Johnson [more]
Unread 18-01-2008, 13:06
eaglesfan10's Avatar
eaglesfan10 eaglesfan10 is offline
FRC #1647 (Iron Devils)
eaglesfan10 is an unknown quantity at this point
The Best Remote to Use?
I was wondering if anyone can recommend a good remote for the robot. Will any remote work just as well as any other? In the kickoff demo and in the manual they show a comcast remote- is this the best choice?
Unread 18-01-2008, 13:32
tanmaker
Posts: n/a
Re: The Best Remote to Use?
Any remote will work the same as any other. You can add extra IR LED's to make it more powerful, but other than that, they are equal
Unread 18-01-2008, 14:33
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I have to respectfully disagree with you on that, tanmaker.
Remotes do have different range capabilities, so picking the right remote could be important (although most remotes will handle this competition just fine).
Additionally, different remotes handle signals differently. Some send 1 pulse for each button press, while others will send a continuous stream of pulses as long as the button is held down. This aspect is perhaps more important than the strength of the remote (as i said, most will work fine for this competition), as it involves programming your robot differently based on the remote. If you know you'll only get 1 pulse per button press (regardless of how long you hold it down), then you can treat each pulse as a separate press. If you have that same code but a remote that sends a continuous signal of pulses as long as the button is held down, odds are you'll get multiple signals to the robot for each button press and possible unintended results.
Unread 18-01-2008, 16:22
Can anyone recommend a certain brand or model that has had exceptional results?
Unread 18-01-2008, 17:49
CzarValvador's Avatar
CzarValvador CzarValvador is offline
AKA: Val
FRC #1717 (D'penguineers)
Team Role: Electrical
CzarValvador has a spectacular aura aboutCzarValvador has a spectacular aura about
If I'm right, the Remote that is the best is the one that has the Biggest Difference from the Frequency of all the other remotes.
Interference is going to be impossible to avoid from the tests that we conducted, unless all the remotes are 1000nm wavelength, and your remote is something like 750nm.
Basically, Expect interference.
Unread 22-01-2008, 07:38
858member 858member is offline
AKA: Alex Julien
FRC #0858 (Delphi Demons)
Team Role: Mechanical
858member is an unknown quantity at this point
Any remote would work but I would reccomend a good universal remote. They have good range and great quality. Of course, universals aren't cheap, but if your team can pay for a regional and the kit of parts, then I'm sure that getting a universal wouldn't be that bad.
Unread 22-01-2008, 10:21
AlCapowned AlCapowned is offline
Junior Member
None #9420
AlCapowned can only hope to improve
I am a huge fan of this remote. It is really nice and can pretty much do anything for you I own it.
Unread 02-02-2008, 15:26
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
If you use a universal remote, remember to program it to pretend to be a remote you know works. Otherwise, it just acts weird.
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
BEST USE of the IR Remote!!! waialua359 Control System 34 13-01-2008 10:55
What kind of battery does your IR remote use? Elgin Clock Electrical 0 09-01-2008 12:14
What are the best wheels to use on carpet? The GarbageMan Kit & Additional Hardware 10 09-04-2007 20:29
Remote Remote Kickoff for Southern California ChrisH Southern California Regional Robotics Forum 0 05-01-2004 12:36
Remote Remote Kick off at University High School George1902 Off-Season Events 4 04-01-2004 21:05
