Go to Post Time flies when you're freaking out. - Koko Ed [more]
Unread 18-01-2008, 13:54
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
Team Role: Coach
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
pic: 2008 Crossmembers Together
Unread 18-01-2008, 13:55
Éowyn Éowyn is offline
no team ((no team))
Éowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to beholdÉowyn is a splendid one to behold
Re: pic: 2008 Crossmembers Together
Ooo . . . shiny aluminum.
Unread 18-01-2008, 14:03
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Nice looking.... what is being mounted to the smaller holes?
Unread 18-01-2008, 21:43
unclewaldo unclewaldo is offline
Fabrication/Assembly/Cat Herder
FRC #0911 (WestBots)
unclewaldo is a jewel in the roughunclewaldo is a jewel in the roughunclewaldo is a jewel in the rough
Hope you have done you weight calculations....
Doesn't look like you have much left to cheese out if weight becomes an issue..
But... nice milling... Being a Fabrication/Assembly biased FIRST member, It is nice to see 'custom components' being designed and fabbed for a unique result.... are these conventional [old school... old guys rule!! ] or CNC [PHD] milled parts????
Unread 19-01-2008, 00:52
redbarron's Avatar
Mike Barron
AKA: Mike
Team Role: Coach
Those are just mounting holes that we always add to the bot for later use. We drill .201" holes all around so that when we want to mount something we can either put a 10-32 bolt through and fasten or tap to fit a 1/4-20 bolt.
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
Unread 19-01-2008, 00:56
redbarron's Avatar
Mike Barron
AKA: Mike
Team Role: Coach
We used almost the same base last year so we know what the approximate weight is going to be and we actually had all 4x4 throughout the whole frame last year and decided to use 2x4 for the cross members and 4x4 on the side rails which will lighten it up even more
The Red Dragons
2008 Offseason event MARC being moved to JUNE 28, 2008 Steve Ketron Off-Season Events 10 21-03-2008 07:55
pic: Finished 2008 Robot!!! ZachKahn Extra Discussion 7 08-01-2008 19:58
pic: FRC 2008 Field robostangs548 Extra Discussion 3 07-01-2008 17:22
pic: 179 & 1889 Look Good Together Swampdude Extra Discussion 13 31-01-2007 21:37
pic: FRC488 Chassis Coming Together Madison Extra Discussion 6 17-01-2007 18:18
