Go to Post How FIRST is helping: teaching me just how much I can achieve in 6 weeks. - Otaku [more]
Unread 18-01-2008, 20:19
pbrules15 pbrules15 is offline
AKA: Ronny
pbrules15 is an unknown quantity at this point
Rule question
Are there any rules against having a light, strobe, or LED on the robot this year?
I looked through the rulebook, and could not find it, can you help?
Unread 18-01-2008, 20:34
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Rule question
I would construe a strobe as a distraction to opposing drivers/impediment of their vision and therefore illegal. LED or another type of light would probably be legal, provided that they don't distract other drivers.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 19-01-2008, 23:55
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Rule question
Under Robot rules
<R02>Items specifically PROHIBITED from use on the ROBOT include:
 Any devices or decorations specifically intended to jam or interfere with the remote sensing
capabilities (including vision systems, acoustic range finders, sonars, infra-red proximity
detectors, etc.) of another robot (i.e. changing ROBOT color to confuse opponent’s vision
system)
And
<R20> Any non-functional decorations included on the ROBOT must not affect the outcome of the
MATCH, and must be in the spirit of “Gracious Professionalism.”
All of the above are and will be under the scrutiny of the inspection team.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 20-01-2008, 13:51
robbrad robbrad is offline
FRC #1875 (Autonomato Autonomatons)
Team Role: Electrical
robbrad is an unknown quantity at this point
Re: Rule question
As long as they don't interfere in any manner, there shouldn't be a problem. Run your decorations through a seperate circuit with it's own toggle switch incase the inspectors say otherwise. They shouldn't make you take them off if their operation proves illegal, they just won't let you run them during the match.
Unread 21-01-2008, 07:19
Unsung FIRST Hero
Rookie Year: 1996
Re: Rule question
It is not neccessary to add the weight of a toggle switch and wiring. Non-functional decorations that require power must run through a breaker and be powered from the main battery. As such it is a simple matter of removing the breaker that feeds the decorations to prevent them from lighting.
Al
WB9UVJ
www.wildstang.org
Rule R-16 question lopz056 Rules/Strategy 6 08-01-2008 22:39
Question on rule S03 colt527 Rules/Strategy 2 10-01-2006 20:18
Rule M7 Question Stephen Kowski General Forum 2 13-02-2003 14:00
RULE Question. archiver 2001 7 24-06-2002 00:38
rule question.... archiver 2001 1 23-06-2002 22:54
