Go to Post Gotta love it... FIRST's GDC...providing entertainment to loads of bored Bostonian FIRST'ers on a friday night. - Andy Grady [more]
Unread 19-01-2008, 00:10
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Microchip C-Bot, easyC Pro or MPLAB IDE?
Hi, my team is currently searching for where to download the C compiler to program our FRC comtroller. We have easyCPro that came with the kit, but the tutorials on
http://www.usfirst.org/community/frc...nt.aspx?id=482
speak of a different compiler called Microchip C-Bot and the tutorial found at
http://www.ifirobotics.com/docs/lega...2-apr-2004.pdf
speaks of another compiler called MPLAB IDE.
We decided to follow the tutorials, but we can't find where to dl Microchip C-Bot. My question is which one is the correct one to use for 2008? Also, are there any tutorials that would go with this compiler. We would prefer to work with line-based code.
Thanks very much!
Windell
Unread 19-01-2008, 08:33
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Microchip C-Bot, easyC Pro or MPLAB IDE?
The CBot compact disk came in the Kit-of-Parts wrapped in with the white clipboard.
It has the manuals, MPLAB IDE, and mcc18 compiler.
Unread 19-01-2008, 09:19
robotrobot2's Avatar
robotrobot2 robotrobot2 is offline
Computer Overlord
FRC #0151 (Tough Techs)
robotrobot2 is on a distinguished road
You might also want to look at C-free 4, which is a good code developing environment and has a good compiler.
Everything can always be blamed on software:
The claw can't pick up the trackball-
programmers must have messed up the claw function.
The driver crashes the robot into a wall-
the drive code must not be responsive enough.
The robot repeatedly displays "HELLO WORLD"-
that probably is software.
Unread 19-01-2008, 09:22
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
easyC Pro has the compiler bilt in.
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 19-01-2008, 16:18
FRC #2477
Thank you very much! Found it. For the sake of curiosity what is the the difference between MPLAB IDE and easyC if they both have text-based compilers?
thanks,
windell
Unread 19-01-2008, 19:55
Just Itinerant
MPLAB is a text-only editor.
EasyC is a graphical editor with text editing capabilities.
Both tools handle compilation for you using the same mcc18 compiler and associated tools.
EasyC has it's own built-in robot download tool.
The separate IFI_Loader application must be used to download the robot-ready output produced by MPLAB.
Unread 20-01-2008, 05:49
FRC #2477
Thank you very much Mark for clearing things up! I understand now.
MS Vista/EasyC & EasyC Pro rswsmay Programming 1 25-04-2007 10:47
MPLAB IDE rholokleolke Programming 13 08-12-2006 18:32
MPLAB IDE HELP Idaman323 Programming 2 16-02-2005 18:01
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
