Go to Post Q: "What does your robot do?" A: "It collects data about the surrounding environment, then discards it and drives into walls" - tsaksa [more]
Go Back   Chief Delphi > Other > VEX
Unread 19-01-2008, 09:38
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
Question Tether
Does anyone know where I can purchase a Tether to connect the VEX controller to the the control module? I have the ones that come in the kits, but I would like the long ones that are required at the practice fields.
Unread 19-01-2008, 10:07
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Tether
wal mart sells long telephone handset cords....is that what you mean?
Unread 19-01-2008, 10:18
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: Tether
I got a 25ft cable for $1 at a dollar tree.
Eric Haskins KC9JVH
Unread 19-01-2008, 13:13
Sunny
Rookie Year: 2007
Re: Tether
Will regular tethers work for the VEX robot or do they have to be some special cord?
Unread 19-01-2008, 17:50
AKA: Eric Haskins
Re: Tether
The tether cable for Vex is the same as the wire that runs between a corded phone and the base. It's narrower than a regular phone line. Its a standard cord that should be availible at any electronics store.
Eric Haskins KC9JVH
Unread 19-01-2008, 17:53
edgar_amaro edgar_amaro is offline
FRC #2582 (Pantherbots)
Team Role: Student
edgar_amaro is on a distinguished road
Re: Tether
Hey!!! what is the distance between the floor & the bottom of the chassi
& the floor & the bumppers supose to be
Unread 19-01-2008, 18:18
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
Rookie Year: 2007
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Tether
umm...i believe you're in the wrong thread!? do you mean the bumpers FRC robots are required to have?
if you want to know the distance between the floor and you're chassis it can be anything you want as long as some form of movement is involved (or one of my crazy ideas in FTC was to build a giant stationary arm that could reach anywhere on the field, didn't have the parts
Unread 19-01-2008, 21:39
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
Re: Tether
...the wire that runs between a corded phone and the base...
This should be reworded into "the cables that run between phone handsets and the cradles of (non-"Princess") phones that don't have almost all of their circuitry embedded in the handset". That cable is different from the cable that runs from the cradle to a wall port.
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 19-01-2008, 21:41
Emily Horsman
Rookie Year: 2007
Re: Tether
i learned that the hard way!! no practice at the comp. for me, what type of cable is this!?
Unread 20-01-2008, 09:16
Sunny
Rookie Year: 2007
Re: Tether
I think that is the wire that connects the headset and the base of the phone and not the base to the wall...right?
Unread 20-01-2008, 11:30
fredliu168's Avatar
fredliu168 fredliu168 is offline
FTC #0478 (Mustang Robotics 478)
fredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud of
Send a message via MSN to fredliu168
Re: Tether
You didn't get a cable? We handed out free tethers to every team in the Ontario competition.
In 2006
Team Name: 3652 FLAME
Michigan VEX Competition WINNERS
Pennsylvania VEX Competition WINNERS
Atlanta World Championships Runner-up alliance
Only team to win two regionals in 2006
In 2007
Team Name: 478 Mustang Robotics and 163 UHS Robotics
Events:
Toronto FTC Competition - Finalists (478, 163, 298)
MA FTC Competition - Winners! (738, 478, 427)
Unread 20-01-2008, 18:58
Sunny
Rookie Year: 2007
Re: Tether
Hey, why don't you send me his tether.
I don't think he'll mind....
Just playing with ya Andy.
Tether Pinout roboticsguy1988 Electrical 4 15-01-2006 20:36
Tether heating up! Shu Song Electrical 10 03-02-2005 01:14
tether edomus Technical Discussion 7 06-03-2004 20:04
Power to RC through Tether zdude255 Control System 4 04-02-2004 19:40
tether after a match archiver 2001 9 24-06-2002 02:09
