Go to Post Excuse me while I rant on your comment here a bit. - Andrew Remmers [more]
Unread 19-01-2008, 11:50
robotrobot2's Avatar
robotrobot2 robotrobot2 is offline
Computer Overlord
FRC #0151 (Tough Techs)
robotrobot2 is on a distinguished road
IR alternatives
I'm not sure about this, but I think that under signaling devices in the rules, it says that you can use sonic, IR, or visible light. If this is allowed, how would you set up a system that uses sound or visible light?
Everything can always be blamed on software:
The claw can't pick up the trackball-
programmers must have messed up the claw function.
The driver crashes the robot into a wall-
the drive code must not be responsive enough.
The robot repeatedly displays "HELLO WORLD"-
that probably is software.
Unread 19-01-2008, 14:56
DonRotolo's Avatar
Back to humble
FRC #0832
Re: IR alternatives
The short version is "put a sensor on the robot that can detect "_____" (IR/Light/Sound) and then program it so it responds to four different inputs".
The longer version is left as an exercise for the astute student.
Don
MPLAB alternatives? bronxbomber92 Programming 12 21-11-2008 17:36
Ramp alternatives? Andrew1742 General Forum 6 25-01-2007 10:33
CMUcam2 alternatives? groves Technical Discussion 6 10-01-2007 10:09
Gear alternatives Booger Technical Discussion 6 23-07-2006 02:27
VEX Alternatives... 114gopher FIRST Tech Challenge 3 24-04-2005 20:02
