Go to Post FIRST is, of course, a grand social experiment in American culture - jonathan lall [more]
Unread 19-01-2008, 14:51
fabalafae's Avatar
fabalafae fabalafae is offline
Guardian of the Grimmerie
FRC #0540 (TALON)
Rookie Year: 2007
fabalafae is an unknown quantity at this point
IR Sensor
On the IR board, do we connect the output signal to positive or signal on a PWM cable?
SVP
Thank you.
I am stricken and can't let you go
When the heart is cold, there's no hope, and we know
That I am crippled by all that you've done
Into the abyss will I run
Unread 19-01-2008, 16:53
CyDrive's Avatar
CyDrive CyDrive is offline
FRC #1203 (pandemonium)
Rookie Year: 2007
CyDrive is an unknown quantity at this point
Re: IR Sensor
If you are referring to the pins that send data from the ir board to the robot then yes. Those should be connected to the white cable on the pwm cable. Also make sure to hook the black part of the pwm cable up to a ground wire on the board.
Sensor Molten Programming 3 17-02-2007 17:43
Banner Sensor Wstedtlogan Electrical 1 20-12-2004 17:21
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
Sensor Q Brew Technical Discussion 2 10-02-2002 12:48
Sensor Oakridege_665 Technical Discussion 5 10-01-2002 16:53
