Go to Post You have not only joined a robotic competition, you will discover that you are becoming a member of a very large and wonderful family. The more years that you participate, the larger your FIRST family will become. - Car Nack [more]
Unread 19-01-2008, 20:21
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Rookie Year: 2000
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
Use a Potentiometer to Tune your programs
We implemented this simple idea and it worked so well that I though it should be posted for others to steal.
Ever need to tune a value in your program to make the output behave in particular manner but get frustrated by having to edit-compile-download every time? Then this is for you.
Get a low-cost 5 to 100 k-ohm single-turn potentiometer (RadioShack has them). Connect to a PWM cable as shown in the picture below.
Connect the cable to an analog input and you are done with the hardware.
In software, add the code below into your default and autonomous functions to read the pot:
#define TWEAK_POT rc_ana_in16 //we use channel 16
unsigned int tweak_pot; //variable declaration
tweak_pot = (unsigned int)Get_Analog_Value(TWEAK_POT);
Now you are all set to use the tweak_pot variable in your code. Remember the following points:
-the analog value will be read as a number between 0 and 1023. Zero will be when the potentiometer is rotated full counter-clockwise if you have it connected as in the picture.
-if you need the number converted to a value compatible with a PWM output (8-bit), divide by 4. (new_value = (unsigned char)(tweak_pot >> 2)
-the tweak_pot value is updated every time the loop is executed giving you real-time control of the variable in the RC.
-You can do a similar effect with a joystick on the operator interface, but that input will be limited to a range of 0 to 255.
We have used this approach to great advantage when tuning our autonomous PID code.
You can use more than one tweak pot--you are limited to 16 by the RC.
Happy coding and Good Luck Teams!
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
i would like your opinion on my programs CmptrGk Programming 14 14-10-2004 21:28
Favorite FF tune Raven_Writer Chit-Chat 5 22-09-2004 07:53
Video Editing Programs...share what you use and why... Alexander McGee 3D Animation and Competition 25 09-01-2003 22:27
Code for use of a potentiometer wonderdog5 Programming 2 06-11-2002 23:15
Code for use of a potentiometer wonderdog5 OCCRA 2 06-11-2002 23:15
