Go to Post Gracious Professionalism is being embarrassed at an event by an underperforming catstrophe of a robot, yet standing and applauding for every award because you realize that as hard as you worked that season, the other team must have worked even harder to get their achievements. - Taylor [more]
Unread 21-01-2008, 15:16
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Overpass rigidity?
Originally Posted by dlavery View Post
I don't know if the trucks that transport the fields around will be carrying any extra field parts. Based on past practice, I would doubt it. But all they will really need is one of these:
-dave
Dave,
They had one at kickoff but were using it to separate the center plates with the velcro on them from the carpet.
I think it is safe to say, plan on some sag when you are setting/adjusting your max robot height to go under the bar.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-01-2008, 14:51
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
FRC #0254 (The Cheesy Poofs)
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Originally Posted by M. Krass View Post
Has anyone else with a field built to spec. found this to be true? I'm curious how much of the deflection we're seeing might be present in the FIRST fields or if it's something that's unique to ours that we should try to fix.
We built an overpass out of steel pipe, pretty much exactly to spec. Don't know about bounciness, but it does sag a couple of inches in the centre of the span.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 21-01-2008, 15:22
Given To Fly's Avatar
Given To Fly Given To Fly is offline
Pearl Jam man
AKA: Tony Frates
FRC #2761 (Iron Horse)
Team Role: Teacher
Given To Fly will become famous soon enough
We are using black PVC pipe too. We only built one section of half of the field's overhead track. Sturdy for sure!
Hurdling using the overpass robogeek753 Rules/Strategy 40 20-01-2008 17:02
removing trackball from overpass Tyler Grooms Rules/Strategy 4 15-01-2008 12:39
under overpass Bohalin General Forum 4 14-01-2008 11:47
rule question on scoring above overpass Robo_Coyote Rules/Strategy 35 08-01-2008 09:03
Height of overpass Evert General Forum 8 07-01-2008 14:11
