Go to Post To anyone who is discouraged about their team, don't let yourself get down. I've seen my team go from having a robot that barely moved (and I'm not kidding, we had keys falling out of gearboxes) to this year with a robot that is ACTUALLY GOING TO WORK. Don't lose hope, stick with FIRST! - ZipTie3182 [more]
Unread 20-01-2008, 13:01
interfect interfect is offline
FRC #2022
interfect will become famous soon enough
Eclipse Plugin Source
Hello,
Anyone know where I can get the source for the Eclipse FIRST plugins (ie the MCC toolchain and error parser plugins)? They're being annoying for me, and working in some versions of Eclipse and not others, and I want to see if I can make them work properly.
Unread 20-01-2008, 23:34
StevenB StevenB is online now
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Eclipse Plugin Source
I don't know much about Eclipse plugins, but the mcc18 plugin I've used is simply a jar file (which is actually a zip archive). If you extract that, you should have all of the source. It's an XML file and some package meta-info.
The version on Astronouth7303's site is also a jar file, and should be similar.
http://www.astro73.com/download/eclipse/fdt/plugins/
File Type: zip org.eclipse.cdt.mcc18.toolchain_1.2.0.zip (2.9 KB, 138 views)
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 22-01-2008, 01:01
shtylman shtylman is offline
some sort of programmer
FRC #2420
shtylman has a spectacular aura aboutshtylman has a spectacular aura about
I got a hold of the plugins and cleaned them up a bit. You can download my versions through the update manager. More info: http://shtylman.com/frc/
If you want a copy of the sources just PM or email me and I will send them over.
Eclipse Plugin, Linux, and a Java Loader shtylman Programming 5 17-01-2008 14:44
"Full screen mode" in Eclipse/Easy Eclipse Kelly Programming 0 15-07-2007 16:37
Eclipse Plugin Maintaineer? duane Programming 21 31-10-2006 22:34
Lego 3dsmax plugin? Ian Curtis 3D Animation and Competition 4 03-04-2005 18:59
inventor plugin Lev 3D Animation and Competition 0 05-01-2003 22:53
