Getting Code From Bot
I'm my teams programmer and i'm relatively new to this. My question is, is there a way to reverse download a code off of the bot and into a project you can look at in easyC pro?
Re: Getting Code From Bot
There is no utility for downloading the code from the robot controller back to your computer. Understand that the program in your RC is a binary, meaning it has been compiled into format that the RC can understand....which mean it is not a format that you would understand.
I suggest you look at the excellent tutorials in the Help section of EasyC Pro. To start with you can try a simple program, such as compressor operation. |
| Getting the Camera and Default Code to Work | nukem | Programming | 5 | 18-01-2006 11:48 |
| Getting A Bot To Turn | Andrew Blair | Technical Discussion | 20 | 16-10-2005 23:49 |
| GETTING AWAY FROM THOSE WALLS? | J15.5h | General Forum | 6 | 10-12-2004 16:13 |
| Getting an image from a website | Raven_Writer | Website Design/Showcase | 17 | 09-06-2004 11:39 |
| Getting program from RC | PhatalEphekt | Programming | 4 | 18-02-2003 17:44 |
