Go to Post Scouting wins championships folks...not draft orders. - Andy Grady [more]
Unread 20-01-2008, 18:29
K.Porter's Avatar
K.Porter K.Porter is offline
Not So Random!
FRC #0172 (FALGOR)
Team Role: Electrical
K.Porter will become famous soon enough
Send a message via AIM to K.Porter Send a message via MSN to K.Porter
PWM Cables - Locking disconnects?
I am currently wiring my team's gear tooth sensors, and I would like to have a locking disconnect in the wire, so that the gear box with the sensors enclosed can be quickly and easily removed without wires getting in the way.
I have contemplated cutting and soldering the stock PWM cables and connectos, but I've decided against it for a number of reasons (don't want a solder splice there, don't want the chance of the connection falling apart too easily)
What I am looking for is a connector that has male/female pins that can be crimped to the individual wires of the PWM cable and then inserted into a plastic case. (preferably a case that locks when connected) I used such a system for the same gauge wires at my place of work over the summer, but I don't have access to them at the present time. When I used the connectors there, I believe they were referred to as "C Grid" connectors, but a search of that name has brought me nothing.
If anyone could point me to a location where I could buy these connectors (and what they are actually called) that would be great!
Thanks.
Unread 20-01-2008, 18:49
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: PWM Cables - Locking disconnects?
What exactly are you asking? Like how can you attach the cables to your GTSs (gear tooth sensors) and have them removable? If this is what you're asking, I would stick the male end of a pwm cable through the GTS, cut off the excess, bend the terminals to make it easier to solder, solder them, and then you have a regular PWM connection that is removable because the female end can easily be plugged in and unplugged.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 20-01-2008, 19:05
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
The C-Grid connectors are made by Molex. ( www.molex.com -> connectors -> wire to wire -> overview -> C-Grid / SL)
You can buy them from several places, including Mouser and DigiKey.
I would recommend going through molex, and then clicking "Check Distributor Inventory"
I do like this series of connectors, as you can get them with polarizing tabs.
Unread 20-01-2008, 19:24
K.Porter's Avatar
Not So Random!
FRC #0172 (FALGOR)
Sorry, apparently I wasn't very clear.
I'm looking for wire connectors (something similar to the Anderson Power Poles, but for much smaller gauge). I've already soldered connectors for the sensors, and I'm looking for a connector to add to the leads to I won't have to de-solder or cut the wires.
Thanks to EricVanWyk, that's what I was looking for. Any other suggestions of similar products would be much appreciated as well.
Unread 21-01-2008, 08:24
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Molex makes a variety of small connectors using nylon housings that you can use. Check the Digikey website/catalog. Digikey also sells a universal crimper that will do both the standard PWM pins and a variety of other pins as well. It is WM9999-ND and it sells for $50.
Any insulated connector that fits in your budget and does not expose power supply pins to shorting to frame or other electronics should be fine.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-01-2008, 08:53
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
In the past, when Team95 has had several PWM cables running to some remote location (like up the center of a rotating arm), we've run cat5 cable with breakout boxes on each end to act as quick disconnects. (http://www.sparkfun.com/commerce/pro...roducts_id=716 is a board that even breaks everything out nicely)
Unread 21-01-2008, 11:54
K.Porter's Avatar
Not So Random!
FRC #0172 (FALGOR)
Thanks for all the input guys!
I had never thought of using CAT5 cables before, but that certainly sounds better than terminal strips and 10-conductor cable like I've used in the past. I'll certainly look into that if the need arises.
Unread 21-01-2008, 12:19
Unsung FIRST Hero
Rookie Year: 1996
Although many teams use CAT 5 I don't recommend them. CAT 5 is solid conductor wire and breakage is common on moving devices and rough handling.
Al
WB9UVJ
www.wildstang.org
Unread 21-01-2008, 12:26
DonRotolo's Avatar
Back to humble
FRC #0832
It is possible to get CAT5 in stranded, it is used for patch cords.
I completely agree, solid wire has no place on a robot, it will break.
Don
Unread 21-01-2008, 13:44
kaszeta's Avatar
Don is indeed right, I should've made it clear to use CAT5 patch cable for this if you're planning on doing it.
I highly recommend good, modular construction and use of wiring harnesses. Nothing is worse than working on a bot in the pits that's hardwired everywhere.
Unread 21-01-2008, 19:54
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
I've seen CAT5 in various (26, 24, 22) AWG sizes, be sure to check <R70> when choosing your wire.
Making PWM cables? HokieTutorunie Electrical 9 08-04-2007 12:29
PWM Cables Alex Cormier FIRST Tech Challenge 15 13-08-2006 09:48
PWM Cables zachriggle Electrical 3 04-02-2006 13:54
Bad Pwm cables Greg Needel Electrical 7 18-01-2006 23:13
The PWM Cables amateurrobotguy General Forum 1 22-02-2005 17:42
