Go to Post The season ended. Not cool. - Koko Ed [more]
  #16   Spotlight this post!
Unread 25-01-2008, 00:32
Capt. Quirk Capt. Quirk is offline
AKA: Bill Mazzacane
FRC #1704 (Robotic Steelers)
Rookie Year: 2007
Capt. Quirk will become famous soon enoughCapt. Quirk will become famous soon enough
Re: Wheel direct drive
Originally Posted by DarkFlame145 View Post
I have to agree with everyone. The only advantage i can think of is it's lighter. But you lose top end speed, and bat. life
A 4" wheel mounted directly to a CIM should produce at least 75 ft/sec. (assuming a max rps of 71)
Too Fast. There is no need for a larger the wheel. Good programming should help the speed and control. Also I would like to reiterate what Al Skierkiewicz said:
Originally Posted by Al Skierkiewicz View Post
Just to add a word of caution, direct drive will require some additional bearing support if you plan on adding wheels to the output shafts. Failure to provide adequate support will increase the bearing friction at the output of the transmission which results in high current and early failure of the bearings. Many teams that use chains forget this point as well. Unsupported side loads, transfer the load to the bearings and internal mechanics resulting in significant wear and friction. The friction is in turn reflected as high current in the drive motor which in turn causes excessive heat.
Direct Drive from Toughbox Gearbox diesel Technical Discussion 11 16-01-2008 04:30
Running Banebots Transmission in Direct Drive Marcel Motors 6 27-01-2007 22:20
Help! Direct Drive Issues roberthan Motors 16 21-09-2006 09:33
pic: 1097 Direct Drive 01 Anthony Kesich Robot Showcase 16 13-09-2005 22:33
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
