Go to Post Time flies when you're freaking out. - Koko Ed [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 20-01-2008, 20:22
Pi Boy's Avatar
Pi Boy Pi Boy is offline
Programming Mentor
AKA: Case
FRC #0461 (Vikings)
Rookie Year: 2000
Pi Boy is an unknown quantity at this point
Programming the IR
Sorry if this question might have been asked before, but just for reference, what programming language do you use for the infrared Sensor?
There are two different types of people in this world. Those who do FIRST and those who don't.
Unread 20-01-2008, 20:25
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: Programming the IR
I'm pretty sure you aren't allowed to program the sensor itself, you normally just program the robot to react to the digital signals it outputs.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 20-01-2008, 21:33
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
When someone refers to "programming" the IR sensor board, they're probably talking about teaching it to recognize signals. That's done by following the directions in the FIRST IR User Guide.
Unread 21-01-2008, 15:47
Pi Boy's Avatar
Programming Mentor
AKA: Case
FRC #0461 (Vikings)
Rookie Year: 2000
thanks a bunch, I wonder why I couldn't have found that sooner....:/
programming the pneumatics Armando Programming 2 17-02-2007 21:47
Programming the vex microcontroller to respond to commands on the serial port crashoverride02 Programming 1 20-10-2006 14:17
Programming The CMUcam for the Vex controller 987HighRoller Programming 3 24-06-2006 15:27
Programming the IR James Hine Programming 1 10-03-2004 14:08
programming the compressor archiver 2001 4 23-06-2002 23:19
