Go to Post The robot is never 'done' there is always something that can be done to improve it. - Jonathan Norris [more]
Unread 20-01-2008, 20:40
sea_master's Avatar
sea_master sea_master is offline
AKA: the $@#$@#$@#$@#$@#$@# guy
FRC #1947 (the black knights)
Team Role: Driver
sea_master is on a distinguished road
Send a message via ICQ to sea_master Send a message via MSN to sea_master
pic: a weak ago
Unread 20-01-2008, 20:42
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
Re: pic: a weak ago
If you rotate the Toughboxes 180 degrees you will move the output sprocket lower so you can mount the 45 degree plate to the kitbot rail. Is there a reason for making the middle mount between the two toughboxes ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 21-01-2008, 11:48
roboticWanderor's Avatar
roboticWanderor roboticWanderor is offline
Spark The Ancient
FRC #0418 (Purple Haze)
roboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant futureroboticWanderor has a brilliant future
Re: pic: a weak ago
yes, they are hiding something behind that black wall!
Unread 21-01-2008, 16:34
Ben Piecuch Ben Piecuch is offline
Bengineer
Rookie Year: 2000
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: pic: a weak ago
If this is a test bed drivetrain, then congrats on getting it built and ready to run. If this is your 2008 robot, I have some very important comments to make.
1) If you're running one piece of chain from the gearbox to both wheels, I highly recommend that you get some more "wrap" around the gearbox sprocket. The right side drive looks to have the chain already connected, and I can imagine that there isn't much engagement with the sprocket.
2) The aluminum plate that is mounted atop the black box (between the new toughbox angle brackets) is no longer available from IFI. If you manufactured this yourself, nice job. If you are using a left over piece from the previous kitbot, it is not legal for the 2008 competition.
3) The skyway wheels are mounted to the chassis using the plastic molded hub adapters from previous KOP's. Again, these adapters a no longer manufactured, and are not legal for the 2008 competition.
Just trying to help you out early, before you get to your first inspection on Thursday. Best of luck,
Bengineer
Unread 21-01-2008, 17:04
sea_master's Avatar
Team Role: Driver
Re: pic: a weak ago
thank you for pointing it out
we will make some changes
phase 1: collect underpants
phase 2:???
phase 3: profit!
pic: 437 a week ago NextPerception Robot Showcase 1 22-02-2006 23:04
weak link which probaly plagued many Bots archiver 2000 1 23-06-2002 22:44
Segway invented 15 years ago in Japan dense Dean Kamen's Inventions 2 09-03-2002 23:32
