Go to Post We don't tell new mentors about the Mentor VIP Adults Only Lounge, you'll get your key if we approve. We have leather couches, flat screens, and free corndogs in there. - Monochron [more]
Unread 20-01-2008, 21:14
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Gear Tooth Sensor Wire Gauge
<R47> All main and branch circuits shall be wired with appropriately sized wire:
 12 AWG or larger diameter wire must be used for all circuits protected by a 40A circuit
breaker.
 14 AWG or larger diameter wire must be used for all circuits protected by a 30A circuit
breaker.
 18 AWG or larger diameter wire must be used for all circuits protected by a 20A circuit
breaker.
 24 AWG or larger diameter wire must be used for providing power to pneumatic valves.
<R55>
 Power feeds to custom circuits and additional
electronics must be protected with a 20A circuit
breaker.
The rules specify that custom circuits (including sensors) must be protected by 20A snap-action breakers, but I can't figure out how I would hook 18 AWG wire up to a gear tooth sensor. Furthermore, I know that using a smaller gauge wire would cause an unsafe situation because the wire would overheat before popping the breaker.
<R45> Items specifically PROHIBITED from use on the ROBOT include:
 Fuse panels different from those provided in the Kit Of Parts
Ok, so having a sub-panel is out.
What do I do? Do I just hook up the 24 AWG wire I've been using for the GTS to the breaker panel and hope they don't notice at inspection? Since the sensors have been around for awhile, I assume there's an acceptable solution.
Gear Tooth Sensor marco_alchemy Electrical 7 06-02-2008 09:54
How do you wire the gear tooth sensor? 1594code Electrical 5 12-01-2008 16:24
Gear Tooth Sensor? Raikon Kit & Additional Hardware 3 09-02-2007 16:40
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
Line sensor wire gauge questions Dinush Electrical 6 13-02-2004 18:41
