SONAR sensors for collision avoidance
Hi, I'm currently searching for a SONAR sensor to use for collision avoidance on our bot. An example sensor I am looking at is at the following link.
http://www.robotshop.ca/home/supplie...der-srf05.html Do any of you have any experience using such a sensor? Is there any example code? Thanks, Windel |
Re: SONAR sensors for collision avoidance
Thanks for your response! Hmm damping function. What do you mean by this? is this a mathematical damping function?
(a) if object is within 12", only drive the motors at 2/3 the commanded speed (b) if object is within 6", only drive the motors at 1/3 the commanded speed Using this approach, we could run out robot at full speed towards a box on the field, and it would only lightly bump it. |
There is also some useful info in this thread.
I have played with the $30 Maxbotix sensor with a Vex bot, and I am very impressed with its range, accuracy, ease of interfacing and cost/value ratio. I am pushing the team to use them for this year's Hybrid mode. Don |
| Ultrasonic rangers for obstacle avoidance | pogenwurst | Programming | 5 | 11-01-2008 19:22 |
| Maxbotix Sonar Sensor | DonRotolo | Electrical | 17 | 04-02-2007 12:27 |
| Collision avoidance during autonomous | Andrew Schuetze | Programming | 5 | 17-01-2006 13:24 |
| Collision Detection in Inventor? | jlewellen | Inventor | 2 | 06-01-2005 21:29 |
| Grady personal injury avoidance tip #2 | archiver | 2001 | 27 | 24-06-2002 00:05 |
