Go to Post Teamwork has always gotten us somewhere. - Arefin Bari [more]
Unread 21-01-2008, 03:01
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Tracking x y coordinates using GTS
Hi, I've been reading some threads on using accelorometers and gyroscopes and performing integrations to track the x y coordinate of a robot. It seems that by what I see there is some vibration issues and filtering issues related to doing this.
To try to remain as simple as possible I am wishing to use the gear tooth sensors to monitor the position of each wheel to determine the x y coordinate of the robot. I hope to use the difference of wheel travel sensed by each sensor to indicate how far the robot has rotated and traveled in a direction.
Does anyone have any advice as to how I could do this practically? This reminds me of line integrals.
Thanks,
Windell
#2477
Unread 21-01-2008, 08:46
Los Frijoles's Avatar
Los Frijoles Los Frijoles is offline
Stormin' Mormon
AKA: Kevin Cuzner
FRC #2062 (C.O.R.E.)
Rookie Year: 2007
Los Frijoles has a spectacular aura aboutLos Frijoles has a spectacular aura about
Send a message via AIM to Los Frijoles
Re: Tracking x y coordinates using GTS
This thread has some gear tooth sensor code posted by one of the mentors of my team.
Using a switch of some sort to set the initial position of the robot, it would be possible to use the sensors to determine the x y position of the robot. There may be some trig involved, but I mostly see a need for extreme usage of the pythagorean theorum. Please remember that the sqaure root function takes a long time to execute on the PIC processor, so use it sparingly.
Community Of Robotic Engineers 2062
Blender totally pwns 3DS Max...
My life is here and here.
Cuznersoft Hardware and Software Development
Unread 22-01-2008, 10:37
slickwill1675 slickwill1675 is offline
FRC #0247
slickwill1675 is an unknown quantity at this point
I haven't had much luck with the gear tooth sensors. You might be better off with an encoder. Their about 50 bucks but extremely accurate. If you buy an encoder with an index of 200 and mount it to the shaft of your drive wheels it will count 200 per 1 revolution of your wheel. So if you had a 8inch wheel, it would count every time you move about .126 of an inch. Also it will tell you direction the wheel is turning, unlike the gear tooth sensor.
Right now I'm trying to figure out how to use a combination of our two encoders and gyro to determine our location on an (X,Y) plane. Has anyone had any luck with this?
Thanks,
Will
#247
Unread 22-01-2008, 16:41
FRC #2477
Thanks Will! Do you have any suggestions as to an encoder?
Unread 22-01-2008, 17:40
DonRotolo's Avatar
Back to humble
FRC #0832
For distance you'll do fine with encoders/GTS, but the slip when you turn will be too variable to accurately keep track of the amount of turning. Also, the errors will accumulate if you're not careful.
Turning is best sensed with a gyro and timer: If the rate gyro says you're turning at 15 degrees per second, and you do that for 6 seconds, you've gone 90 degrees to a fairly high degree of accuracy.
Unread 22-01-2008, 17:57
sea_master's Avatar
sea_master sea_master is offline
AKA: the $@#$@#$@#$@#$@#$@# guy
FRC #1947 (the black knights)
Team Role: Driver
sea_master is on a distinguished road
Send a message via ICQ to sea_master Send a message via MSN to sea_master
what about using the accelerometers to know how much the robot has traveled? and the gyro for the change of angles.. that way you also cover the x y axis
phase 1: collect underpants
phase 2:???
phase 3: profit!
Camera locked in "tracking", but not tracking geeknerd99 Programming 1 18-02-2007 22:47
Using kevin's code for driving and camera tracking razzoc Programming 3 18-02-2007 08:50
Enabling Multiple Light Tracking Using Kevin's Code Mitch Programming 7 05-02-2007 06:17
Finding Coordinates of "The Blob" Jatheon4316 Programming 4 30-06-2005 10:45
Map Coordinates on imported objects Jacob Reif 3D Animation and Competition 2 04-02-2003 01:27
