Go to Post Then you might have a 1902 (oink oink BOOM) which could result in a 418 (Purple Haze). - JaneYoung [more]
Unread 21-01-2008, 03:08
arpitshah arpitshah is offline
FRC #1514
arpitshah is an unknown quantity at this point
Question problem connecting the solenoid
hi guys... we r using the pneumatics for the first time and we are facing some technical problems.... we can't figure out that How we attech the single switch solenoid to the circuit....coz we can not find any point on the solenoid where we can attach the wire...so if u guys can help us figuring it out....thanks
Unread 21-01-2008, 08:47
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: problem connecting the solenoid
If you are talking about the SMC valve then black is for ground and red would go to a spike relay. You could connect both to the relay if you have no need to use the other output on the relay.
If you are talking about the Festo valve, you need to wire it yourself. The connector is included in the box. 1- Negative(ground) 2- Positive (spike) 3- not used.
Andy Brockway
Team 716, The Who'sCTEKS
Mounting / Connecting The Fisher Price Motor Xufer Motors 21 31-01-2006 20:16
gear tooth sensor connecting problem nirty Electrical 2 23-01-2006 12:17
connecting CMUCam2 with a PC without the RC winners Programming 1 13-01-2006 20:16
Connecting the controller Max Brin Technical Discussion 1 12-01-2006 11:24
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
