Go to Post How well does peanut butter transmit heat? - Lil' Lavery [more]
Unread 21-01-2008, 08:56
JohnStewart JohnStewart is offline
JohnStewart is an unknown quantity at this point
mplink errors in eclipse
I tried using eclipse ide for code development. But I get a funny error during the mplink step. I tried the same mplink command from a shell and that works fine. Why does eclipse cause this problem?
Here's the build error from eclipse.
Building target: BallBot_2008.hex
Invoking: MPLINK Linker
mplink "..\18F8722.lkr" /a INHX32 /w /m FRCMapfile.map /o"BallBot_2008.hex" ./ifi_startup.o ./ifi_utilities.o ./main.o ./user_SerialDrv.o ./user_routines.o ./user_routines_fast.o /l"C:\mcc18\lib" ..\FRC_library_8722.lib
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - unrecognized input: C:/msys/1.0/a
Errors : 1
make: *** [BallBot_2008.hex] Error 1
Unread 22-01-2008, 08:36
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Re: mplink errors in eclipse
My environment is eclipse on Windows XP.
I saw the same problem after installing msys (in order to get the rm command to fix the "clean" problem with eclipse) I uninstalled msys and switched to GnuWin32. Everything is fine now.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Visual Studio C18/MPLINK build rules >>>HERE<<< itsnotabigtruck Programming 4 03-03-2008 07:48
Build problems: MPLink 4.15 Linker... help? Trav-O Programming 2 12-01-2008 14:26
Mplink error jimmyrock88 Programming 2 14-11-2007 15:50
"Full screen mode" in Eclipse/Easy Eclipse Kelly Programming 0 15-07-2007 16:37
MPLink Error cloudago Programming 2 01-02-2005 23:00
