Go to Post .....just don't hurt the programmer =) - mtaman02 [more]
Unread 21-01-2008, 15:35
sonicx059's Avatar
sonicx059 sonicx059 is offline
Philosophy or Robotics? BOTH.
FRC #1439 (ROBO Raiders)
Team Role: Leadership
sonicx059 will become famous soon enough
Send a message via Yahoo to sonicx059
Help with programing saitekx36f joystick and throttle
I am having a hard time trying to find what the pins do for the controller. I sent an e-mail to their tech support but that doesn't work anyone where i can find this information that i seek.
The right path is my path.
Knowing is not enough, you must apply.
Willing is not enough, you must do. ~Bruce Lee
A man is bound only by the chains that he binds himself with. ~Demario Mitchell
Unread 21-01-2008, 15:55
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
Rookie Year: 2007
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: Help with programing saitekx36f joystick and throttle
If you're lazy you could just print out all input from the port and try and figure out what it's giving you. Otherwise, I have no idea.
Unread 21-01-2008, 16:13
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
Either print values for each variable (p1_x, p1_y, etc) to the screen and see what changes as you push each joystick button or get a multimeter and measure voltage at each pin.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 21-01-2008, 16:32
sonicx059's Avatar
Thanks you all i will try it but we are closing up shop today.
Unread 21-01-2008, 20:30
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I don't think even Saitek can be sure what the pins on the X36F do anymore. Development on that device was discontinued a decade ago. It uses a bizarre combination of serial port, keyboard port, and game port connections in order to communicate with a driver that runs only on the Windows 98 operating system.
The only way I know of to connect it to an IFI Operator Interface joystick port (without ripping the guts out of the joystick and rewiring it as a simpler 15-pin game port device) is to also use an X36T USB throttle control and a Chicklet USB-to-joystick-port converter. You might get lucky and find that it works as an Aviator or ST290, but you more likely will have to pay for the Chicklet to be reprogrammed to recognize the X36 system.
NEED PROGRAMMER TO HELP WITH PROGRAMING Reaper40 Programming 4 02-02-2007 17:31
Help with joystick lightning_blast Programming 2 12-02-2006 22:25
Programing a joystick Justin_302 Programming 2 21-03-2005 22:45
Help with Joystick Axes and Sensitivity bglass Programming 6 06-02-2005 14:01
help with programing banner senor. incognito_NICK Programming 2 17-11-2004 06:51
