Go to Post When we got it tuned to the point where we were (reasonably) confident it wouldn't slam into Dave's ankle, we quit for the evening. - Kevin Watson [more]
Unread 21-01-2008, 16:44
beemgruem's Avatar
beemgruem beemgruem is offline
AKA: Begüm
FRC #2905 (Sultans of Turkey)
beemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to behold
TEam #2531's Robot-- Chassis and Electrical Board is done!!
Hope you guys like it!!
If the link does not work click here to see..
And also there is a teaser in the corner
Let's see who can guess
Begüm
Unread 21-01-2008, 16:46
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
Re: TEam #2531's Robot-- Chassis and Electrical Board is done!!
Do I see some scissor lifts?
Unread 21-01-2008, 18:06
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Team Role: Coach
Rookie Year: 1996
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Consider mounting the radio vertical as suggested last year by IFI.
Mike Martus
Unread 21-01-2008, 18:36
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Look really nice Begum! The positioning of the toughboxes is a good idea!
so that is what those white andy mark thingie are for...they are for the anderson connectors
hmmm an extra victor and 2 extra spikes
Im guessing a CIM motor to move the scissor lift up and down, and 2 window motors to control the manipulator
good luck! looking forward to seeing the finished product
btw, Ill get you a pic of our finished electronics board once we trash the prototype
Unread 21-01-2008, 19:10
DonRotolo's Avatar
Back to humble
FRC #0832
Aside from some (minor) wire dressing needed (a few zip ties and 15 minutes), that looks very nice - a robust design that is simple and easy to troubleshoot. Yes, the radio prefers to be vertical, since the outside antenna is *not* the only antenna in the system, there's one inside the box as well. Also easy enough to change, once the manipulastor's on board.
Don
Unread 21-01-2008, 21:03
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
They were designed as flags for charged batteries. Several years ago, the TechnoKats had a huge pile of yellow ones made to give away at competitions. We stick them in a battery connector as we remove a fully charged battery from the charger. They have to be removed in order to use the battery, so we know a flagged battery is good to go, and a non-flagged battery needs to be charged.
We have a stack of red ones as well. We use them as "lock-out" plugs when a robot is being worked on and should not be powered up. (We also use them on occasion to flag batteries that appear to be faulty and shouldn't be used until they've been checked out.)
Unread 21-01-2008, 22:14
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
Team Role: Coach
Rookie Year: 2000
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Looks like your ready to roll. The wire sizes look good and the colors are right. Please take some time to make the wires nice and neat and label every thing. If you need some ideas http://www.team1322.org/electrical.htm
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 21-01-2008, 22:25
1619Aaron's Avatar
1619Aaron 1619Aaron is offline
FRC #1619
1619Aaron is an unknown quantity at this point
Is that a two-wheel caster design? If it is, I can tell you from experiance (2005) that it is not a good idea. You won't have nearly as much finite control as you would like. It swings all over the place.
Unread 22-01-2008, 17:34
joeweber's Avatar
Coach team 1322
Team Role: Coach
Rookie Year: 2000
Casters can be squirrelly, but with the right programming it’s probably the simplest system to use. You can add program so when you go faster the turning becomes less. I would suggest that you make the casters the front of the robot so you won’t get stuck against the wall unable to turn without backing up.
Unread 22-01-2008, 21:10
beemgruem's Avatar
AKA: Begüm
Yes, they are fron wheels And we did not have any problems with turning, driving is really easy, and there is no problem.. As soon as I have time, I will put the video of driving of our robot
Thank you for positive feedbacK!!
Begüm
Unread 22-01-2008, 21:14
beemgruem's Avatar
AKA: Begüm
Actually we are using CIMS for driving, and we have not decided the lifting motors and its victors are not on the electrical board yet..
BTW, yeah its scissor lift, but our lifting system wont be just scissor lift
Wait and see
Begüm
Unread 22-01-2008, 22:08
esisso esisso is offline
AKA: Eitan
FRC #1242 (Team Smiley)
Team Role: Mechanical
esisso will become famous soon enough
Send a message via AIM to esisso Send a message via MSN to esisso
looks good...but i would consider upgrading a couple things
-get 2 cim motors mounted per gearbox
-get andy mark molded plastic omni-wheels for the front, your driving and steering will improve tremendously
-consider moving your ON/OFF (power) switch to somewhere more convenient, closer to the edge maybe
-lastly, i recommend you switch out that wood for plexiglass for weight and amazing looks =D
good luck! contact me if you need help with anything
Unread 22-01-2008, 22:30
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Don't use Plexiglas for that purpose. You'll regret it. (Plexiglas is acrylic, and shatters easily. It's also difficult to machine.)
If you must have something transparent, use polycarbonate, which is tougher and easier to work with. But plywood isn't that bad either—good-quality plywood is stiff for its weight, and even easier to work with.
Unread 22-01-2008, 23:01
AKA: Eitan
maybe we should change ours then hehe.....we have used plexiglass for about 4 years in a row with no issues yet
  #15   Spotlight this post!
Unread 23-01-2008, 12:31
arhajder's Avatar
arhajder arhajder is offline
Arkadiusz Hajder
FRC #0640 (Viro)
Team Role: Leadership
arhajder will become famous soon enougharhajder will become famous soon enough
Send a message via AIM to arhajder
I didn't see any compressor and it doesn't look like there is much space for any of the pneumatics so how you guys going about that?
chassis almost done!!!! DarkFlame145 Robot Showcase 9 15-01-2008 22:33
Team 1527 Chassis/Electrical/Pneumatics Design... cdennisxlx2 Technical Discussion 9 09-01-2008 01:38
Team 172 - Electrical Done! K.Porter Robot Showcase 18 08-02-2007 20:44
pic: 1323 Chassis and electrical Robo_Coyote Extra Discussion 8 20-01-2007 21:32
pic: Team 1726 MegaMaid Motors/Chassis/electronic board yodameister Robot Showcase 3 11-02-2006 01:21
