Go to Post To sum it up... We know nothing. - BJC [more]
Unread 21-01-2008, 19:07
Rachel M's Avatar
Rachel M Rachel M is offline
FRC #0304 (RoboGriffins)
Team Role: Leadership
Rachel M will become famous soon enoughRachel M will become famous soon enough
Send a message via AIM to Rachel M
Robocoach communication
I have read the manual many times but I have not found a rule for or against communication between the driver and robocoach. With all the drivers and robocoaches on the field and the possibility of distance between them I find communication is going to be hard. Is there a rule or lack of a rule about communication like walkie-talkies or bluetooth or anything?
Unread 21-01-2008, 19:14
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Re: Robocoach communication
Walkie-talkies are out (Section 3.3, last bullet). I would also assume Bluetooth is out, due to the following (rule shortened for readability):
<R02> ROBOT parts shall not be made from hazardous materials, be unsafe, or cause an unsafe condition. Items specifically PROHIBITED from use on the ROBOT include:
 Shields, curtains, or any other devices or materials designed or used to obstruct or limit the vision of any DRIVERS and/or COACHES and/or interfere their ability to safely control their ROBOT
(emphasis mine)
IIRC, Bluetooth is infrared based. I would assume that you can't use it due to interference risk.
Also see <T22>.
<T22> The only equipment that may be brought on to the field is the OPERATOR CONSOLE, reasonable decorative items, and special clothing and/or equipment required due to a disability. Other items, particularly those intended to provide a competitive advantage for the ROBOCOACH, are prohibited.
Devices used solely for the purpose of planning or tracking strategy of game play are allowed inside the ALLIANCE ZONE, if they meet ALL of the following conditions:
 Do not connect or attach to the OPERATOR CONSOLE
 Do not connect or attach to the FIELD or ARENA
 Do not connect or attach to another alliance member
 Do not communicate with anything or anyone outside of the ALLIANCE ZONE (for example wireless communications must be disabled).
 Do not in any way affect the outcome of a MATCH, other than by allowing team members to plan or track strategy for the purposes of communication of that strategy to other alliance members.
So, communication would be allowed (not disallowed), but it can't use wireless communications. Other means would need to follow the rules as well.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 21-01-2008, 19:26
Rachel M's Avatar
Thank you so much for your help. It sounds like my team needs to do some major brainstorming and possibly learning sign language.
Unread 22-01-2008, 01:38
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Bluetooth is RF based, not IR based. I agree with the rest of what you said though.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Robocoach signals loophole? jacobhurwitz Rules/Strategy 51 29-01-2008 09:16
Robocoach fashion accessories flightofone General Forum 7 20-01-2008 14:43
How many RoboCoach Commands? compwiz2008 Rules/Strategy 59 11-01-2008 16:46
<G49> ROBOCOACH Signaling t3hroxor Rules/Strategy 3 09-01-2008 20:41
One RoboCoach Per Team? mr_yes General Forum 4 07-01-2008 13:33
