Go to Post My puppy certainly thanks the many teams that handed out frisbees this year. - VexisDarksteele [more]
Unread 22-01-2008, 09:22
esisso esisso is offline
AKA: Eitan
FRC #1242 (Team Smiley)
Team Role: Mechanical
esisso will become famous soon enough
Send a message via AIM to esisso Send a message via MSN to esisso
Belt drive
We figured out a way to attach the belt gears to a shaft; however, we don't know how to attach belts to the gears and tension them...anybody have tutorials/ vids/ samples?
Unread 22-01-2008, 09:59
Fab.Master's Avatar
Fab.Master Fab.Master is offline
FRC #0617 (Locomotives)
Fab.Master will become famous soon enough
Cool Re: Belt drive
http://www.chiefdelphi.com/media/photos/29719
Unread 22-01-2008, 13:28
AKA: Eitan
Re: Belt drive
im not sure i understand as to how it works still..anybody else have more input? i dont want track drives, i want a belt system...the 5mm stuff we got this year, not to drive the wheels but for an arm component
Unread 22-01-2008, 13:39
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Belt drive
Did you find the literature from Gates about the belts that was in with the kit of parts?
Usually there are two ways to tension a belt: you make it so the shaft that supports one of the pulleys can be moved away from the other pulley, or you add a third pulley called an "idler" that just pushes the belt from the side and keeps it tight.
The only toothed belt I have handy for reference is this one on my car
it uses an idler that pushes against the inside of the belt.
Unread 22-01-2008, 13:54
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Belt drive
Sometimes, a little bit of slack in the belt won't hurt (mainly conveyors). Not the case on an arm, though. Go with a tensioner.
Or...precision-drill the hole locations for the belt's shafts and hope it holds tension. I've done that--330 (2006) had a very high RPM motor attached to a belt, and we never tensioned, other than location of the other end. The same went for the other belt system on the same structure. (We did have one other belt, but one of the two units was tensioned and one was not. I forget which one was on the robot. It was also a very different type of belt.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 22-01-2008, 22:36
AKA: Eitan
Re: Belt drive
i am loving that "idle pulley" system, i'll design something...thank you!
Unread 22-01-2008, 23:16
Nightfall831 Nightfall831 is offline
AKA: Paul
FRC #0888 (Robotiators)
Rookie Year: 2007
Nightfall831 will become famous soon enoughNightfall831 will become famous soon enough
Send a message via AIM to Nightfall831
Re: Belt drive
and what kind of car does that supercharger belong to?
That's a PEBKAC problem. (Problem Exists Between Keyboard And Chair)
^Yea, I never run into those...
Unread 22-01-2008, 23:19
MrForbes's Avatar
AKA: Jim
Re: Belt drive
it's on the 454 in my 55 chevy in my avatar
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
Timing Belt Drive System maclaren Technical Discussion 31 01-08-2006 10:08
pic: Belt drive 1559 krADLEY Robot Showcase 8 01-02-2006 21:37
Drive belt Rachika Garcia Rules/Strategy 3 10-01-2006 21:19
belt drive/tank treads dradius Kit & Additional Hardware 14 19-06-2005 23:16
