Go to Post For some strange reason, people always seem to spell my last name incorrectly. I'm not really sure why. - Karthik [more]
Unread 22-01-2008, 09:48
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Pitfalls of having a "wide" robot?
Because of various design issues and the "80 inch rule," we are thinking about turning our frame side ways and putting the drive wheels on the short axis. We are looking at a frame 36" wide by 26" long. With a far shorter wheelbase, are there going to be problems with turning something this wide. is there a disadvantage to powering all four wheels?
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
Unread 22-01-2008, 10:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Pitfalls of having a "wide" robot?
Having a wide 4 wheel drive skid steer robot makes for easier turning than a narrow one.
But it affects how easy it is to tip over....look at the distance between where the wheels contact the floor. With a normal configuration, this distance is similar for both directions, while a wide robot has a very short wheelbase, and is much more likely to fall over if bumped near the top, especially if it's top heavy to start with.
Some teams have used this design with an extendable "wheelie bar".
Unread 22-01-2008, 10:10
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
If anything, turning will become much easier due to the shorter wheelbase. Assuming your wheels are standard "grippy" wheels and you power all of them, it's easier to turn a wider robot with this configuration than it is a longer bot.
However, you must consider other drawbacks to using a wider design - first and foremost, how stable will you be if you have an arm that reaches high in the air? Remember, you should also consider external bumper zone forces from other robots in your design. If "tippiness" is a problem, you may choose to incorporate a simple extendable wheelie bar in the front and/or back of your robot (can be as simple as a pneumatic cylinder pointing at the ground with a PVC endcap attached to the end of it - 48 did this in 2003 to stabilize our short wheelbase robot and minimize the risk of tipping over when driving up the ramp).
You must also consider that you will be a "wide load" when driving around the track - you will take up more track width and are therefore more likely to block traffic - you are also more likely to be blocked by other traffic, as you aren't as easily able to squeeze through tight spaces.
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 22-01-2008, 11:28
wilsonmw04's Avatar
Coach
Team Role: Teacher
Rookie Year: 2007
thanks for the replies. We have ditched the arms this year and going for a low profile machine. The tallest part of the robot will be the top of the ball. I was concerned with the power needed to turn and the "jumping" while it skids. You have put them to rest. thanks again.
Unread 22-01-2008, 12:55
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
The tallest part of your robot should be the top of the flag holder at 51 inches per <R017>.
http://www.usfirst.org/uploadedFiles...Robot-RevC.pdf
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 22-01-2008, 13:01
wilsonmw04's Avatar
Coach
Team Role: Teacher
Rookie Year: 2007
I always forget about that when talking about the Robot. You are right and it is the tallest portion of the robot.
Unread 22-01-2008, 11:36
Mr.Rush Mr.Rush is offline
AKA: Braden Rush
FRC #0401
Mr.Rush is on a distinguished road
yet another team opts for a push bot speed demon....our paper weight is doomed ^-^
Unread 22-01-2008, 12:46
wilsonmw04's Avatar
Coach
Team Role: Teacher
Rookie Year: 2007
We aren't pushing, we're grabbing :-)
Unread 22-01-2008, 11:38
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Driving 36" wide will make turning a lot easier. In addition, it will make the robot less tippy while turning. You will need to take care because you will be tippy while accellerating. If you have problems while accellerating, I'd suggest a wheelie bar or moving some heavy objects within the robot forward in the chassis.
We are driving wide this year as well, and we've had excellent success the last 2 years in this configuration.
Powering all 4 wheels is generally recommended as well as running chains between them, although this will add a lot of weight to your drivetrain. This gives you good pushing power and accelleration. If you use grippy tires you should be able to corner well in this configuration.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 22-01-2008, 11:42
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
the further corners are from the center of the bot the more leverage you have to push it arround.
you can't get more extreme than this when it comes to wide robots
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
I'm having difficulties locating the programming code "gift" Flynn Programming 3 09-01-2005 22:01
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? gnormhurst Programming 3 22-02-2004 02:55
