Go to Post Never, Never tell a prospective mentor what the actual job description is. You need to get them hooked first. :D - BJT [more]
Unread 23-01-2008, 09:46
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
static local variables
Is there a correct way to define a variable inside a function as "static" so it retains a value between invocations of the function? I've resorted to a user code block in order to do it so far. Unfortunately, that doesn't make the variable "known" to the rest of the EasyC system -- it won't show up in the drop-down menus, for example.
Unread 23-01-2008, 10:11
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Re: static local variables
You can use a user code block and it must be in the first line of the function. Like you mentioned, shown below but you are correct it will not make the variable known. We had this in easyC for FRC 2 years ago and it caused allot of problems with users mis-using it.
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Why Static Variables? brianafischer Programming 13 26-01-2007 14:56
Static Cling?? orelinde Electrical 17 27-02-2006 17:33
Static Variables amateurrobotguy Programming 8 04-03-2005 00:40
Static Electricity JeffO Championship Event 5 19-04-2004 11:04
Static Electricity archiver 2001 12 24-06-2002 00:34
