Go to Post Things are not always as simple as they seem. - Paul Copioli [more]
Unread 23-01-2008, 15:32
eaglesfan10's Avatar
eaglesfan10 eaglesfan10 is offline
FRC #1647 (Iron Devils)
eaglesfan10 is an unknown quantity at this point
Integrating Encoder
I was wondering if anyone has successfully integrated encoder code with Kevin's MCC18 ver2.4 new code. I tried with instructions that I read somewhere else on the forum, but I couldn't get a reading from the encoders, and could can readings using last year's encoder project. I really don't want to upgrade to the 3.10 version of the compiler because on the front page of ifi's website it says:DO NOT upgrade C18 Complier - We do not support upgrades. Use ver 2.4 supplied in your Kit.
I anyone has any suggestions on how to integrate the encoders I'd really appreciate it. Thanks.
Unread 23-01-2008, 16:20
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: Integrating Encoder
I assure you that IFI and FIRST know about my code, so you're free to use the 3.1 compiler. You just can't expect to receive support for my code from IFI. If you still want to use the 2.4 compiler, I'll be releasing the 2.4 friendly versions tonight or tomorrow.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Integrating accelerometer output Jared Russell Programming 7 12-01-2008 01:24
Integrating Gear Tooth Sensor magical hands Programming 2 19-02-2007 20:29
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
Help Integrating Interrupts and Camera Keo-san Programming 6 25-01-2007 22:20
Integrating Robotics into school curriculum nalbonec Starting New Teams 5 14-01-2006 15:17
