Go to Post I'm always afraid of what the GDC will come up with... Their sanity is often questioned... :D - thefro526 [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 23-01-2008, 17:13
ALARM Robotics ALARM Robotics is offline
FRC #2079
ALARM Robotics is an unknown quantity at this point
Forklift Design Help!!!
We are making a forklift this year and have come up with a potential design. The design has stages mounted in front of eachother and will use drawer slides or igus linear slides. Do you think there is too much force on the slides if we do a 4 foot stage with 10 inch overlap? Should we go with an imbedded u-channel design instead and how can we do this? Here is the design:
Thank you very much!
Unread 23-01-2008, 17:16
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Re: Forklift Design Help!!!
It should be noted for future browsers on this thread that your attachment is a PDF file, and not an image so that's why it's not showing up with the image command.
http://alarmrobotics.wikispaces.com/...e/Forklift.PDF
^ correct link.
That said, it certainly looks feasable. 10" should be more than enough overlap with a 3 level system.
1" overlap = very bad & unstable!
Your 10" should be about right if not more than enough imho.
Good luck!
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 23-01-2008, 17:51
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
We have used similar designs in the past and I don't see any glaring errors in the drawing you provided. Always consider the mass of the ball when you are working on drive code. A big ball, high up, will make the robot unstable as the center of gravity moves further from the floor. Practice, Practice, Practice!
Al
WB9UVJ
www.wildstang.org
________________________
Unread 23-01-2008, 17:59
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Looks pretty solid. We did one like that before, but if you want to, you could put each successive level inside the other (like a commercial forklift) instead of in front and having cross bracing.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 23-01-2008, 18:08
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
KTorak's idea would be good, but I suggest against it. It is simply too time consuming for the season. The actual design looks good. The main problem our team came against last year was that our motor was strugling against the friction/weight. Just keep these in mind while wiring/chaining and you should be fine.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 23-01-2008, 18:19
FRC #2079
Thanks for everyone's responses so far and correcting the PDF thing, I will make a note of how to do that.
Unread 24-01-2008, 09:41
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I second this notion - It's our teams design for this year, and really isn't all that much more time consuming. We had a prototype made out of wood after the first week and it works very well and is extremely durable, which is something that all teams should think about when going for a tall, hurdling bot - With your CG so high, you do risk tipping over no matter what you do, and if you tip, you have to consider the fact that other teams will be "gently" pushing you out of the way, which could put stress on the lift design where it's not designed for...
Unread 24-01-2008, 10:13
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Your design looks good although I'm a little concerned on your overlap. 10" is about 21% overlap. Considering the weight and combersomeness of the trackball, I'd look for more like 25-30% overlap.
You'll also want to look at the lever forces on your slide pieces to make sure that they will slide (side friction) and not "pull out" (deform) should you get "gently bumped" while you are extended. Also is it powered down as well or are you using gravity?
Also watch your CG when the forklift is extended. I dont see the drive base so I dont know how far forward your CG is. You may find yourself tipping if you drive once extended.
All-in-all, while you have a few challanges to overcome, it looks good.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 24-01-2008, 15:09
FRC #2079
I think we have the CG issue under control because we are going to attach the forklift to a pivot point so that it can tilt back, getting the weight more centered on the robot. Although, I am very concerned about the lever force pulling the slides apart and the added friction. We could definitely do more stages but thought it might add too much weight/complexity. Ideally, we had wanted to do an embedded U-channel type design but don't see how you could run cables between the stages if you go with drawer slides? Also, the lift will be powered down as well as up.
Unread 24-01-2008, 15:30
I'll try to remember to take a picture tonight for you of our prototype, it actually works out pretty well. Like you, we have a three stage design, but ours looks a little like:
Code:
| ______ |
|| ____ ||
|||____|||
||______||
|________|
The center stage is attacked to the forks, and moves completely within the middle stage. The middle stage moves up to the top of the outer stage (with some overlap) and (not pictured here) the outer stage has a support beam at the top that goes behind the middle stage. It was actually pretty simple to hook up pulleys in the expected locations (the top and bottom horizontal support beams) for each stage - they just stick out the back a little instead of all being directly inline with the plane of the rack.
Unread 24-01-2008, 21:29
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
A year or so ago I saw a powerpoint presentation on a team website that talked a LOT about different forklift designs.
What team was that ? Where is the powerpoint ?
Ed Barker
Unread 25-01-2008, 10:03
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
To figure out what motor to use, I'd suggest using this spreadsheet as a rough guide:
http://www.chiefdelphi.com/media/papers/2059
Go to the "linear mechanism" tab. The two #'s 1885 set requirements for was the "Time to move travel distance under load" (< 3 seconds) and "Max loaded current draw" * 12V < half of the peak power rating of the motor. Miraculously, we found 2 perfect matches of motor/gearbox/sprocket combos!
Note that the output current cannot constantly exceed the fuse for that particular motor, for whatever your load is. Actually, if it exceeds a certain amperage consistently, you will burn out the motor. Also note that with a 2-stage elevator, your load is either ~0.9(2*lifted weight) or 1* the weight but you'll have to move 2 times a single stage's travel distance, depending on how you hook it up.
We're lifting ~28lbs including the ball over 3 stages, so we're accounting for 90 lbs and have a slightly larger sprocket ready if we decide it's doing well enough to add some extra speed.
GitHub
FORKLIFT HELP? t41w4ne5ef0b General Forum 12 20-01-2008 18:24
Forklift help!!!!!! The_Laughing_ManMII Technical Discussion 7 14-01-2008 17:17
Slider design help? vivek16 Technical Discussion 4 13-01-2008 16:26
Circuit Design Help Ronald_raygun Electrical 18 26-03-2007 07:32
Transmission Design Help JoelP Technical Discussion 8 24-04-2006 16:59
