Go to Post "FIRST is not about getting as little help as possible - In fact, it's the opposite- the goal is have to make you feel obligated to thank as many people as possible for helping you in ways that you didn't really think you needed or even considered that you could use help." - boomergeek [more]
Unread 23-01-2008, 17:42
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
SMC single acting solenoid
i cant find which each port is for. can someone help me
Unread 24-01-2008, 00:18
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: SMC single acting solenoid
FIRST consult the pneumatics manual.
The SMC valves:
P port: air supply (not the band)
A port: One outlet
B port: The other outlet
EA: Exhaust port
EB: Exhaust port
The exhaust ports don't need to be connected to anything. The outlet ports you connect to your air cylinder. The P port you connect to your working pressure source.
Last edited by TubaMorg : 24-01-2008 at 00:18. Reason: Typoed pneumatics yet again
SMC Solenoid Vendor? sircedric4 Pneumatics 1 17-01-2008 11:30
single solenoid seanl Pneumatics 4 18-02-2007 02:32
Need instructions for SMC Single/Double solenoid WHou Pneumatics 5 29-01-2005 08:17
Using SMC Single Selenoid Valve from last year? Sachiel7 Pneumatics 3 20-01-2005 21:31
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
