Possible MPLab or Equiptment Problems?
Hi,
So, the default code works (the pre-compiled HEX file that came with the default code) the way it's supposed to: joystick forward, robot forward. Joystick backwards, robot backwards. Joystick Right/Left: robot turns right/left. Then, after any change in the programming, after compiling with MPLab and downloading with IFI_Loader, the robot controls become screwy. Joystick forward: robot turns right. Joystick right: robot goes forward. This isn't a problem with the code, as I can put just a single small change (changing a variable name) in the code and this will happen. Does anyone know if this is a compiler/compiler settings problem, or an equipment problem, or something completely different? |
Re: Possible MPLab or Equiptment Problems?
Have you tried recompiling the code without making any changes and then downloading? (Although there shouldn't be any changes between the default hex and the default code... Should there?)
| MPlab giving problems?(or it's us?) | Bomberofdoom | Programming | 2 | 11-01-2007 10:28 |
| Array Problems: Possible<stdio.h> | Alex Wijtowych | Programming | 7 | 26-01-2005 04:39 |
| Problems with MPLAB | Charley | Programming | 20 | 25-02-2004 18:13 |
| Possible Robot controller problems | mpalermo81 | Technical Discussion | 1 | 24-02-2004 22:43 |
| Im Having Problems With Mplab!!!! | hedgehogger | Programming | 2 | 20-01-2004 17:43 |
