Go to Post My team does what works for my team. Let your team do the same. - Alexa Stott [more]
Unread 23-01-2008, 19:47
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Gear tooth sensor not driving to ground
Hi. We hooked our gear tooth sensor to an USB oscilloscope and while its putting out a square wave, its not driving to ground. It ranges from 3.8 to 3.9 volts when plugged into digital input 1. And yes, digital i/o 1 is set as an input in code. If I unplug it from the robot controller. It puts ranges from ground to around 1.4 volts. Probably because it doesnt have 5V then.
Could the sensor be bad?
Brian
Brian K
Team 1225 Robotics Mentor
Gear Tooth Sensor marco_alchemy Electrical 7 06-02-2008 09:54
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
Gear Tooth Sensor Nathan Programming 4 12-01-2008 15:09
Gear Tooth Sensor? Raikon Kit & Additional Hardware 3 09-02-2007 16:40
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
