Question about the Pressure Switch
hey,
Our Pressure switch stops at 110psi. Any idea why? Thanks, Last edited by Bomberofdoom : 24-01-2008 at 15:11. Reason: was not me who mispelled at first post |
Re: Question about the Pressure Switch
The pressure switch is not terribly accurate. That being said, it should allow your system to reach in the 120-130 PSI range. It might be defective and would then need to be replaced.
The pneumatics manual says it is supposed to trip at 115 psi.....
ours has always tripped at 110 - 115 psi indicated pressure. We run the compressor 5-7 seconds longer to reach 120 (programming).
| pressure switch wiring question... | Transformers | Pneumatics | 11 | 16-02-2008 12:55 |
| what is the pressure switch? | Reaper40 | Pneumatics | 2 | 25-01-2007 18:52 |
| Pressure Switch Wiring Question | Matthew_H | Electrical | 4 | 16-02-2004 01:25 |
| Pressure Switch Wiring Question | Matthew_H | Control System | 1 | 08-02-2004 15:28 |
| Question about Pressure Switch | Randy_Ai | Technical Discussion | 1 | 30-01-2002 18:29 |
