Go to Post [You know you've overdosed on FIRST when...] When you discover that the cure to the swine flu is "oink oink BOOM!" - Katie_UPS [more]
Unread 24-01-2008, 12:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Banebots 1/2" shaft encoder for Toughbox?
I was looking at the banebots web page, and found this
http://banebots.com/pc/ELECTRONICS/EN-G0561-KT
it's a quadrature shaft encoder with 128 resolution that mounts on a flat surface and works with a 1/2" shaft.
Like it was made to put on a KOP transmission....
2008 Toughbox vs. Banebots vs. 2006 Gearbox team 2191 Technical Discussion 5 20-01-2008 15:20
BaneBots Encoder Chip # whytheheckme Electrical 1 18-02-2007 16:36
shaft encoder help stephenthe1 Programming 2 03-12-2004 16:09
Wiring "3-pin" Shaft Encoder. Joel J Programming 7 27-02-2004 17:21
supplier for 5/8" shaft david.clark Kit & Additional Hardware 2 17-01-2004 18:13
