Go to Post Every single person on the team, read the manual, cover to cover, NO skimming. Do not give the task of knowing the rules to a few people. Do not pass go, do not collect $200, READ THE MANUAL. - RoboChair [more]
Unread 24-01-2008, 14:50
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
Team Role: Coach
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Installing Servo Shifter on SuperShifter
hey we tried to install the servo to shift on our AndyMark S.S. yesterday and we had trouble figuring it out. we couldnt find and directions explaining how to mount it and what not.
we found this PDF on the AndyMark website:
http://lib.store.yahoo.net/lib/yhst-...hifter-asm.pdf
but it does not seem to help much.
i was wondering if there is another document out there explaining how to install this or if any other teams new what to do.
thanks
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 24-01-2008, 16:30
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
Rookie Year: 2007
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
Re: Installing Servo Shifter on SuperShifter
we ran into the same issue. In the end, we assembled it by looking at this picture
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 24-01-2008, 19:33
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
it the parts that came with there should be a quater hex net with a brass fitting it looks like a nut with a gold selve over it. take that nut and screw it in the hole where the puenmatic cylinder with go. if u need and more help ask me and ill sent u a pic asap.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 27-01-2008, 14:57
Andrew Nabors
AKA: Andrew Nabors
Team Role: Coach
do u have to take that brass sleeve out?
it looks like it was removed from the picture that was linked
thanks.
Unread 27-01-2008, 16:40
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
Team Role: Teacher
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Here are pics from AM and from our website. We used them and they are great!
http://www.phxhs.k12.az.us/education...73&pagecat=367
Faridodin "Fredi" Lajvardi KD7WKD
Unread 27-01-2008, 21:36
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Has anyone had any issues with the servo shifting? Overheating? Long shift delays? Not enough torque? Backup battery drain?
I don't know about anyone else, but seeing that little airplane servo next to the big gearbox bothers me. I havent tried shifting ours yet, still just running them in 1st gear writing hardware level sensor drivers...
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 28-01-2008, 01:30
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
We tried servo shifting, but decided we didn't like it that much. The servo arm seemed to slip along the brass sleve, and the the shifting time seemed a bit high. if we were not going to have pneumatics on the robot, we wouldn't add them in order to have pneumatic shifting, but as long as we have a pneumatic system for other robot components, we'll go ahead and use pneumatics to shift rather than the servos.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 28-01-2008, 01:59
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
-q
last year we had problems with the servo shifting such as not enough power to shift the XRP's and also sometimes we had a dead backup battery and that made it very hard to shift
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Rookie Year: 2007
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Although we have never used Andy Mark gear boxes with servo shifters when used with dewalts on our 2006 robot the servos did not perform so well. The long shifting times and lack of power made shifting a nightmare and it got so bad during the off season that we would shift the bot by hand for demonstrations.
I personally think the weight for one precharged tank and two cylinders would be more than worth not having to worry about servo shifting.
AM Servo Shifter (GEN 2) Transporter1717 General Forum 1 15-01-2008 12:45
pic: 1732's 2 servo shifter John Wanninger Extra Discussion 1 04-03-2007 23:27
Andy Mark AM servo shifter (GEN 2) robotguru1717 Motors 1 25-01-2007 20:23
servo on AM shifter JohnMorenski Technical Discussion 4 18-01-2007 13:46
Servo shifter for AndyMark transmissions Robby Technical Discussion 3 17-01-2006 01:41
