Go to Post Re: New to programming, any tips? Join the mechanical team :) - IndySam [more]
Unread 24-01-2008, 22:18
Jaybee1405
Posts: n/a
pic: 1405 Painted Sky Blue II
Special thanks to 340 (and 424) for help with welding and machining!
Unread 24-01-2008, 22:19
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
Team Role: Teacher
Rookie Year: 2000
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Re: pic: 1405 Painted Sky Blue II
I know why there is a cut-out but I'll keep that little secret to myself. It looks good. Can't wait to see it run fully assembled.
Unread 24-01-2008, 22:24
Scott Carpman's Avatar
Scott Carpman Scott Carpman is offline
FRC #1155 (SciBorgs)
Scott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud ofScott Carpman has much to be proud of
Powder blue makes it a very classy chassis.
RPI '12
Unread 24-01-2008, 22:35
Jaybee1405
Posts: n/a
Hey Rees! I'm Joe (the dude who had the NAVY sweatshirt on)
I forgot to mention in the description:
SPECIAL THANKS TO TEAM 340 (and 424) G.R.R.!!!
They welded the chassis and milled some parts for us. They also provided our team something much more important: FOOD!
Unread 24-01-2008, 23:07
Ben Piecuch Ben Piecuch is offline
Bengineer
Rookie Year: 2000
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Is the warping of the frame from the welding?
Bengineer
Unread 24-01-2008, 23:10
Jaybee1405
Posts: n/a
Bengineer
There is no warping that I can see. Perhaps you're looking at the robot being a little bit off the ground? The kitbot extrusion extends downwards about an inch.
Also, the cardboard it is sitting on isn't perfectly flat.
Unread 24-01-2008, 23:22
Bengineer
Rookie Year: 2000
Sorry, I'm just looking at the top half of the frame (or is it actually the bottom half?) and it just doesn't look straight. I guess it's just an optical illusion from the checkered tablecloth behind it and the rest of the stuff in the room. Best of luck!
Bengineer
Unread 24-01-2008, 23:21
AKA: Rees
Team Role: Teacher
Rookie Year: 2000
Hey Joe, how's Charles IV running? I still have to check out the youtube video.
Last edited by rees2001 : 25-01-2008 at 07:41. Reason: a little slow last night...
Unread 24-01-2008, 23:41
Jaybee1405
Posts: n/a
It was running great, thanks to you guys. We calculated close to 14 fps. We threw a caster on the front for the video. It was painful to take the gearboxes and wheels off yesterday so we could paint it , but it will all be worth it tomorrow
Ben, you may be right. I wasn't looking at that part of the photo. *Runs downstairs to basement to check if frame is warped* It is! By about 3/16 of an inch at most. I don't think this should be a problem, but if it is then we may have to use a "Robot Persuading Tool."
Thanks for pointing that out, the picture seems to exaggerate it a bit.
Unread 25-01-2008, 02:34
scottyh2006's Avatar
scottyh2006 scottyh2006 is offline
AKA: Elmo (and what you gonna do about it)
FRC #0564 (Ditigal Impact)
Team Role: Coach
scottyh2006 is on a distinguished road
i like it. but it DOESNT HAVE WHEELS IS IT GOING TO FLY?? JKJK
Good Luck to all
Unread 25-01-2008, 11:03
Jaybee1405
Posts: n/a
We have two powered 6 inch diam. 2 inch width IFI traction wheels on the back
The front is yet to be revealed
Unread 25-01-2008, 12:01
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Team Role: Leadership
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
I am so excited to see what Finney is coming up with this year! I can not wait to see all of you guys again! Looks good, and I will see you at the regional!
Matt Starke
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 25-01-2008, 17:12
Jaybee1405
Posts: n/a
Matt Starke
thanks matt! see you at RIT
Unread 30-01-2008, 11:42
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Post right above me reported.
pic: Da Bears shaved and painted just for 11! aallen88 Extra Discussion 17 08-11-2006 21:10
pic: Dark Sky Festival Barry Bonzack Extra Discussion 1 04-11-2006 23:50
pic: Team 1388: Reach for the sky Mike Hendricks Robot Showcase 2 23-02-2005 02:01
pic: Team 1405 hanging CD47-Bot Robot Showcase 3 26-02-2004 09:48
pic: Team 1405 hanging CD47-Bot Robot Showcase 1 22-02-2004 21:41
