Go to Post OPR will not get you to Einstein - Paul Copioli [more]
Unread 24-01-2008, 23:22
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Gear Tooth Sensor problem found
Apparently two resistors are switched on one of the gear tooth sensors in the KOP.
R3 and R4 are the ones....see the pics...
http://www.chiefdelphi.com/forums/sh...6&postcount=21
So now we know what we have to do.
The bad board in our case is the one that was cut off the end, that is, the one with J1 and J2, the board with J4 and J5 is good.
But you should double check!
Unread 25-01-2008, 01:03
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
Re: Gear Tooth Sensor problem found
Did the resistor switch cause the Gear Tooth Sensor to go bad ? Or did the Gear Tooth Sensor have some other problem?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 25-01-2008, 01:15
billbo911's Avatar
billbo911 billbo911 is online now
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
First off, how on earth did you figure that out!! And , THANK YOU!!!!!
Now, when I get to the school tomorrow, I'll double check ours. It would be really good to know what the values are supposed to be. Removing and replacing those will be REAL FUN.
Is there a chance you can get cleaner pictures?
If not, I'll get my camera out and see if I can get a couple of really sharp images when I get a chance.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 25-01-2008, 01:24
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Rookie Year: 2000
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
One of our mentors took a magnifying glass and started looking at each of the part numbers. lol. thanks to him, we found the error. and so did team 1726
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 25-01-2008, 02:47
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
The part numbers for R3 and R4 are indeed swapped
on our gear tooth sensor that does not work. Without
a SMD rework station it will be quite a chore to swap
them to their correct positions. Perhaps a customized
soldering iron tip and a pair of tweezers will do it.
Eugene
Unread 25-01-2008, 08:26
MrForbes's Avatar
AKA: Jim
Here is a quote from an email I recieved from my brother...he deals with small circuit boards with surface mount components on a regular basis, and successfully reworks them at home (with the help of his B&L stereo microscope)
"I can swap those in a few minutes, or better yet you can do it yourself.
The trick is the technique.
First, tools. You have to have a microscope or magnifier to see what you're doing, a pair of very good but not too sharp tweezers (I use size 00), and a smallish but not teeny-tiny soldering iron tip. Some smallish solder wick and fine solder (.020" ideal, .031" acceptable) are needed as well.
The first resistor may be removed by placing the soldering iron tip across both ends of the resistor at the same time, so that it is heated up at both ends. Then lift it up with the tweezers, or it comes up on the iron and you pull it off the iron with the tweezers.
Now, use the solder wick to remove the solder from the PC board pad that is on the left if you're right-handed, so that the end closest to the iron still has solder.
Do the same for the other part.
Now, with the correct resistor in the tweezers, hold it in place and heat up the solder blob while pressing the resistor into position. Then quickly solder the other end with the fine solder. Don't linger with the iron; the other end will heat up and the part may stick to the iron again.
Repeat as needed. "
And an addendum....
"First, clean the iron tip by wiping it on a wet sponge.
Then, you need to put a blob of solder on the iron tip to make it want to heat up the resistor. Use more solder than you think is appropriate - the blob has to be at least as long as the resistor to heat both ends simultaneously.
If you don't use the big solder blob, then it's nearly impossible to get the resistor off the board.
This is tricky work! If you don't have a lot of soldering experience, you will probably mess it up...and you need good eyesight and steady hands, and a clean, well lit area to work in.
If there is any type of college or industrial place nearby that deals with small circuit boards they might be willing to help, if you ask nicely....
Unread 25-01-2008, 10:01
billbo911's Avatar
Repeat as needed. "
It looks like your parents did a great job raising you and your brother. You both are excellent examples to follow. Tell your Bro, Thanks from all of us here on CD!!
Unread 25-01-2008, 15:05
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
We fixed ours with a hammer
Unread 25-01-2008, 20:15
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
This is where having great mentors/sponsors is helpful. One of ours has a surface-mount soldering station with a stereoscopic microscope meant for this kind of work, and they were able to help us swap the resistors. We'd already ordered the Honeywell sensors by then, but it's so much more compact to use the kit sensors.
Unread 25-01-2008, 20:16
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
So the board works properly after swapping the resistors?
Unread 25-01-2008, 20:19
usbcd36's Avatar
AKA: "DOS"
Yes, it does.
Unread 26-01-2008, 17:19
JYang's Avatar
JYang JYang is offline
AKA: Jenny
JYang is just really niceJYang is just really niceJYang is just really niceJYang is just really nice
Looking at the PCB from left to right there is a sensor with J1 and J2, then the second board has J4 and J5. Which is the good one and which is the one with the parts in the wrong place?
Thanks.
George
Unread 28-01-2008, 22:50
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Rookie Year: 1999
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
The board with the parts in the wrong place is the end board. It's the gear tooth sensor that only has 1 edge scribed. The other edge is smooth.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Problem with 2008 gear tooth sensor Larry R Sensors 27 18-02-2008 11:39
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
Gear Tooth Sensor Nathan Programming 4 12-01-2008 15:09
gear tooth sensor connecting problem nirty Electrical 2 23-01-2006 12:17
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
