Go to Post I'm not the only one confused. Perfect. - MikLast [more]
Unread 24-01-2008, 23:22
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Gear Tooth Sensor problem found
Apparently two resistors are switched on one of the gear tooth sensors in the KOP.
R3 and R4 are the ones....see the pics...
http://www.chiefdelphi.com/forums/sh...6&postcount=21
So now we know what we have to do.
The bad board in our case is the one that was cut off the end, that is, the one with J1 and J2, the board with J4 and J5 is good.
But you should double check!
Problem with 2008 gear tooth sensor Larry R Sensors 27 18-02-2008 11:39
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
Gear Tooth Sensor Nathan Programming 4 12-01-2008 15:09
gear tooth sensor connecting problem nirty Electrical 2 23-01-2006 12:17
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
