Go to Post There's no feeling quite like that one you get when you're behind the diamond plate controlling a metal beast that you've put your blood (literally), sweat (more literally), and tears (probably literally) into, and it working. Undescribable. - scali [more]
Unread 25-01-2008, 10:06
arhajder's Avatar
arhajder arhajder is offline
Arkadiusz Hajder
FRC #0640 (Viro)
Team Role: Leadership
arhajder will become famous soon enougharhajder will become famous soon enough
Send a message via AIM to arhajder
Exclamation Trackball Spacing
Can anyone tell me what is the spacing between the bars where the trackballs are place? in the manual it says 32" from center to center but that doesnt make sense. Any ideas?
Unread 25-01-2008, 10:11
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Team Role: Teacher
Rookie Year: 1999
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: Trackball Spacing
http://www2.usfirst.org/2008comp/Dra...8_Field_GS.pdf
The drawings say 32". It's 32".
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
why doesn't that make sense?
the square that holds each trackball is made of tubes, the side of the square is 32".
the distance between trackballs is different, and I can not remember it of the top of my head.
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 25-01-2008, 10:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Sure it makes sense, but only if you understand what they are saying...and center-to-center measurements are common in many engineering fields.
The distance between the pipes is just the center-to-center distance, minus the diameter of the pipe (or, minus two times half the diameter of the pipe, which is the same thing)
With 1.5" outside diameter pipe, and 32" center-to-center spacing, the distance between the bars is 30.5"
Unread 25-01-2008, 11:01
arhajder's Avatar
Arkadiusz Hajder
FRC #0640 (Viro)
thank you squirrel that helped alot!
pic: Trackball vs. MiniFRC Trackball Jessica Boucher Extra Discussion 3 08-01-2008 03:08
pic: 2 ringer spacing Ryan Foley Extra Discussion 3 07-01-2007 01:31
Gear Spacing Help AdamHeard Technical Discussion 2 07-01-2007 00:20
Spacing of wheels? archiver 2001 4 23-06-2002 22:56
Spacing of jugs and moveable goals luccul Off-Season Events 3 24-10-2001 21:01
