Go to Post And, if you don't know what something means, say so, we'll be happy to explain. - DonRotolo [more]
Unread 25-01-2008, 13:41
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Pressure Switch code
I am having a problem with our compressor, spikes, and RC. I need to get the pressure switch to tell the spike that is connected to the compressor to turn on unto it read 120psi. Yet I don't even have a spike switching to fwd or rev?
I have this code in right now
if(digital_io_18 == 0)
relay1_fwd == 1;
if(digital_io_18 ==1)
relay1_fwd == 0;
Can some let me know what I am doing wrong?
Thank you
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 25-01-2008, 13:54
slickwill1675 slickwill1675 is offline
FRC #0247
slickwill1675 is an unknown quantity at this point
Re: Pressure Switch code
Your if statements match mine but I think it should be relay1_fwd = 1; not relay1_fwd == 1;
== is for comparing, = is for assigning values
If thats not it, double check that you have the digital i/o set to input. Also check that your code is actually being called. I had my code in user_routines.c/default_routine() which wasn't being called, once i stuck the code in user_routines.c/Process_Data_From_Master_uP() it worked. Also make sure your not in disabled mode. I made the that mistake earlier this week
user_routines.c/User_Initialization()
digital_io_18 = INPUT; //DIGITAL I/O set to input;
Good luck
Unread 25-01-2008, 14:45
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Along with the == vs = confusion, you're reading the wrong thing to test the pressure switch. Writing to digital_io_18 is for configuring the pin as either an input or an output. You want read from rc_dig_in18, which gives you the value of the pin.
Unread 25-01-2008, 14:54
Robostang 548's Avatar
Robostang 548 Robostang 548 is offline
I can program the future...
AKA: Don
FRC #0548 (Robostangs)
Robostang 548 is on a distinguished road
Send a message via AIM to Robostang 548 Send a message via MSN to Robostang 548 Send a message via Yahoo to Robostang 548
You can just do it all in one line.
Code:
relay1_fwd=!rc_dig_in18
-Don
Team 548:
Attending National Championship, Genesee District, Detroit District 2, West Michigan District, Michigan Championship?
PRESSURE SWITCH Mr. Steve Pneumatics 20 01-12-2005 10:20
Pressure switch code kingpin3787 General Forum 11 22-02-2004 21:52
HELP US PLEASE?!?!(pressure switch code) kingpin3787 General Forum 1 21-02-2004 15:13
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
pressure switch Antonio Pneumatics 10 31-01-2003 03:52
