Go to Post None. Ours is anorexic at the moment. Lets see if the building people can come up with a simple tetra-knockdown mechanism. - Fixen [more]
Unread 25-01-2008, 15:23
Magnechu Magnechu is offline
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Team Role: Tactician
Magnechu has a spectacular aura aboutMagnechu has a spectacular aura about
Send a message via AIM to Magnechu
A few questions
A few questions from our team:
Are there any rules against putting two plus cylinders to the same relay?
Are there any changes in the wire gage requirements from last year?
Are we allowed to use a third party camera, instead of the standard one?
Thanks a bunch.
Team 870
Unread 25-01-2008, 15:30
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: A few questions
1. As far as putting two cylinders on the same relay, I assume you mean you would like to actuate two pneumatic solenoids from a single Spike relay. This is permissable.
2. If you are familiar with previous year's wire gauge requirements, you should have no problems locating the specifications in this year's manual.
3. There is no standard camera, but if you would like to use one for robot control, make sure it meets the material utililization flow chart in Section 8 of the manual.
Unread 25-01-2008, 15:33
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: A few questions
Firstly, this is a question I would like to know about as well, I'm pretty sure you can hook up two pistons to the same solenoid, but clarification would be nice.
For the other questions read the manual lol. that may sound like a broken record, but it very important that you read it. It will tell you wire sizes!
And I'm pretty sure you can't use any cameras this year!
Unread 25-01-2008, 15:54
Student Strategist
AKA: Mike Fouchet
FRC #0870 (RICE)
Re: A few questions
Okay, first two questinos answered. Thank you. We checked out the flow chart, and followed it, and with that, it would seem like a camera is not legal at ALL. ?! is that really true? That seems kind of crazy..can anyone confirm this?
Unread 25-01-2008, 16:11
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: A few questions
After following the flow chart, it comes down it is it an off the shelf item, which in our case it will be. We cant buy one of the CMUII cams from IFI right, because that would be a custom part for FIRST thats not in the KOP. So if we got any old off the shelf camera working it should be perfectly legal, agree?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 25-01-2008, 16:13
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Re: A few questions
What part of the flowchart led you to believe that the camera is not legal?
The CMUCam from last year's KOP as well as the CMUCam3 are both legal accorindg to the Q&A posted here
EDIT:Let me clarify a bit, the 2007 KOP camera would be legal as it is still available form IFI, the 2006 KOP camera is illegal as it is no longer available and was custom made for FIRST.
Also any other commercially available, off-the-shelf camera system should be legal provided it is under $400 and communicates with the RC and/or other robot circuitry and not wirelessly to the OI or another device.
Unread 25-01-2008, 16:14
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: A few questions
The 2006 KoP CMU cameras are not legal as those were custom parts in the kit. A new CMU-3 camera which you have to purchase is legal.
(since 2004)
Unread 25-01-2008, 16:15
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: A few questions
http://www.cmucam.org/
There are places to buy the CMU Cam I, II, and III.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 25-01-2008, 17:01
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: A few questions
Two pistons to one solenoid, or two solenoids to one spike, makes no difference, as both are legal. (There is no rules limit to how many pistons you can put on the same solenoid.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Few questions rohit Inventor 5 07-03-2007 09:07
A few questions Chase General Forum 15 14-08-2005 13:29
A few questions... Ryan Dognaux 3D Animation and Competition 3 19-02-2005 22:48
A few questions cheezewiz Programming 7 31-01-2004 00:02
A few questions goegan31 Regional Competitions 1 09-03-2003 20:32
