Go to Post If only we could have Week 6 urgency every week. - Gray Adams [more]
Unread 25-01-2008, 18:11
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Shuper Shifter servos hookup and programming
Hey does anyone know how to hook up the Servos provided for the Super Shifters? And if so does anyone know how to program it (in ROBOTC)?
Thanks in advance.
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 25-01-2008, 19:09
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Shuper Shifter servos hookup and programming
Servos connect directly to a PWM output on the Robot Controller.
Control their position the same way you would control motor speed using a Victor. Setting the PWM output to 0 will drive the servo output to one limit of travel, setting it to 254 will drive it to the other limit, and setting it to 127 will move the servo output to the center of its travel. You'll probably want to experiment to find the proper numbers to put the actuator in the right spots for high and low gear, because the servo can overheat if it's constantly trying to push against a physical limit.
Unread 25-01-2008, 19:30
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
PWM values in ROBOTC are centered around 0, not 127.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 30-01-2008, 20:22
timville's Avatar
timville timville is offline
AKA: Timothy Friez
FRC #1185 (X-Bots)
timville is an unknown quantity at this point
Send a message via AIM to timville
You can use Servos just like you would a motor in ROBOTC:
Assuming the Servo is attached to motor port 3:
motor[port3] = 0; //this will center the servo
motor[port3] = -127; //this will adjust the servo to one extreme
motor[port3] = 127; //this will adjust the servo to the other extreme
2003 - Rookie All-Stars Awards - #1185 (Pittsburgh)
2004-2008 FIRST Volunteer - Ref/Head Ref (Pittsburgh)
2002-2007 FIRST Lego League Volunteer - Head Ref (Pittsburgh)
Unread 30-01-2008, 21:59
MiniNerd24's Avatar
Thanks to all. I thanks you for giving me advaice. Amazingly enough I figured it out the same day I posted but I'll use your advice to attach the new ones to the real robot.
Thanks and could someone close this thread I don't know how.
The system is down.
Rack and Pinion/Motors and servos psniffler Motors 7 25-01-2008 16:16
Programming Servos For AndyMark Transmission de_ Programming 6 30-01-2007 08:52
servos and the camera incognito_NICK Programming 5 09-02-2005 00:00
Encoder Hookup kutty18 Electrical 4 22-01-2005 12:17
Line Sensor hookup Dinush Electrical 9 15-02-2004 23:13
