Go to Post FIRST, an american revolution. - paulcd2000 [more]
Unread 25-01-2008, 20:00
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Pressure Gauge
I cant seem to find the pressure gauge that hooks up to the pressure switch and the relief valve
the kit only gives two pressure gauges right? If I attached both of them to my main and secondary regulators, does that mean I have to purchase another pressure gauge?
also, what is a sub base? what is a gasket? did the kit provide gaskets?
Thank you!
Unread 25-01-2008, 20:50
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Pressure Gauge
Look at Page 13 of the pneumatics manual. The only gauges you really are required to have are the two closest to the compressor: One to show the compressor output pressure (located by the relief valve) and one to show the regulated "working" pressure (at the Norgren regulator). The third gauge shown at the Monnier regulator is optional, only of you need both 60 PSI and some other, lower pressure.
Don
3rd pressure gauge? Maximus123 Pneumatics 1 07-02-2007 00:30
Rules about pressure gauge position Kamen64 Rules/Strategy 1 06-02-2007 19:15
[OCCRA]: Gauge JonMTeam255 OCCRA Q&A 1 24-09-2004 19:01
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
What gauge wires Punjabguy87 Electrical 7 07-02-2004 20:25
