Go to Post People can talk a big game, but unless they start working on what they talk about, nothing will get done. - Lisa Perez [more]
Unread 25-01-2008, 22:27
Zultraranger Zultraranger is offline
FRC #0870
Zultraranger will become famous soon enoughZultraranger will become famous soon enough
Fuse Blow
We have 16 gauge wire running from the pneumatic compressor to the spike and then 14 gauge wire running from the spike to the snap action circuit breaker. Every few times we run the pneumatic system, the 20 AMP fuse keeps on blowing on the spike. I am confused why this is happening and if anyone can help me on this problem?
Unread 25-01-2008, 22:28
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Team Role: Leadership
Rookie Year: 2007
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
Re: Fuse Blow
The compressor can potentially suck more than 20A at turn on, and will blow the fuse in the spike. Per the FRC rules, you can replace it with a 20A circuit breaker.
Fuse Panel Pnakovich Inventor 4 10-02-2007 15:42
Could a magnetic field around CIMs cause fuses to blow? scitobor 617 Electrical 41 15-02-2005 08:56
Fuse Box Rhs953 Electrical 2 09-02-2004 23:19
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Fuse Panels punarhero Electrical 5 18-02-2002 10:52
