Go to Post What can you do? The more time you waste here speculating the less time you have to work on the robot. Go! Build Robots! Now! - Jessica Boucher [more]
Unread 25-01-2008, 23:00
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
Rookie Year: 2007
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
Serial Port Elbows
I remember reading a thread a while ago about a teams electrical board that appeared to not have enough space to easily access the serial ports. I believe someone suggested a port elbow which allowed the tether to be connected from above. Could someone verify if this part exists and if so, where it can be purchased.
Unread 25-01-2008, 23:13
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: Serial Port Elbows
http://www.l-com.com/item.aspx?id=8656
I think you are thinking of this
No Serial Port G1279 Programming 5 10-01-2008 15:15
Which Serial Port? crossedheart Programming 4 08-02-2006 11:35
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Serial Port Programming phrontist General Forum 1 07-02-2004 16:13
No Serial Port Jeff Waegelin Programming 15 09-01-2003 22:29
