Go to Post Having 75% of the drive train without direct connection to the transmission would make me a bit queasy, but then again, I'm not Winnovative. - Taylor [more]
Unread 26-01-2008, 10:28
merybar's Avatar
merybar merybar is offline
AKA: Matt
FRC #0894 (Chargers Robotics)
Team Role: Leadership
merybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of light
Send a message via AIM to merybar
CIM Drive Train motors
Has anybody ever compared 2 v 4 CIM moters for the drive train and how much power you lose?
Thanks
MAtt
894
Unread 26-01-2008, 10:48
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: CIM Drive Train motors
You lose half of the power by having half as many motors.
Unread 27-01-2008, 11:45
merybar's Avatar
AKA: Matt
What about speed?
Unread 27-01-2008, 11:47
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Speed will go up slightly, because you are decreasing the amount of speed lost due to friction. It will NOT double.
Torque will double though so if you want twice the speed, then gear it up more.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 27-01-2008, 11:50
MrForbes's Avatar
AKA: Jim
Maximum top speed you can get should be higher with two motors, since you have twice the power available, but teams usually set up the gearing to limit top speed. There are several reasons for this, including being able to control the robot, and having enough pushing power at low speeds (which you lose when you gear the robot to go faster). A good compromise might be to have a two speed transmission, so you can have good pushing power and still have the robot geared for a fast top speed.
Getting up to top speed will be faster (quicker acceleration) with 4 motors.
Unread 27-01-2008, 12:14
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
JVN has an excel(lent) speed modeler in this white paper. http://www.chiefdelphi.com/media/papers/1676
With it you can change the motor inputs, gearing, weight, etc. and it will generate displacement, velocity, acceleration, and current plots.
He removed it from his recent update, so you'll have to go old school and get the old one.
Ken Patton has a similar spreadsheet, but I don't have a location to direct people to.
Mark
Brick walls are for other people. - Randy Pausch
Unread 27-01-2008, 12:57
merybar's Avatar
AKA: Matt
Ok thanks for the input. In previous years we are all about power and defense. This year we think its more about speed and the reason for not using 4 drive train CIM's is we think we are going to use one some where else.
Thanks for the help!
Unread 27-01-2008, 19:02
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Also remember that if you have double (or triple) the motors on your drivetrain, you're going to drain your power much faster. If you get into a pushing match with a robot that has 2 or 3 motors on each side of its drivetrain and you're running single motors, then you MIGHT actually have the extra voltage in your battery to hold your own.
Food for thought.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 28-01-2008, 01:34
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Food for thought.
not necessarily.... When thoose CIM motors stall they hog power.
our 2006 robot had 1 CIM on each side and they hauled all 120lbs around and after 2 minutes you could tell the battery was getting low.... plus with the other attachments on there the battery drained very fast.
Unread 28-01-2008, 01:40
FRC #0973 (GRR)
Hence the "MIGHT". A number of factors go into how fast your battery drains, but the more motors you have running, the faster it'll drain. The compressor running all the time will kill you also.
2011: ???
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Motors on drive train Zoheb N Motors 3 16-01-2007 12:25
drive train Adama Technical Discussion 30 14-12-2006 20:56
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
