Go to Post If you're not trying to make the best possible product given your set of constraints and resources I'm not quite sure what you're doing. - Aren_Hill [more]
Unread 26-01-2008, 15:21
Vasily Zaitsev's Avatar
Vasily Zaitsev Vasily Zaitsev is offline
FRC #1111 (Power Hawks)
Team Role: Electrical
Vasily Zaitsev is an unknown quantity at this point
Send a message via AIM to Vasily Zaitsev
2008 Omni Drive Code Help
Our robot is using a four wheel, four motor omni drive system. Our code gives good output except for sometimes it swaps outputs. Instead of giving a 250, it gives a 4.
drive_ly and drive_lx are our drive joystick.
motor_fl_1 and all the others are the variables we send to the motors. fl=front left.
pwm_drive_fl are the actual motors.
Heres the code:
Code:
  if ( (drive_ly + drive_lx - 127) > 254 )
    motor_fl_1 = 254;
  else if ( ( drive_ly + drive_lx - 127) < 0 )
    motor_fl_1 = 0;
  else motor_fl_1 = drive_ly + drive_lx - 127;
  if ( ( 127 - drive_ly + drive_lx ) > 254 )
    motor_fr_1 = 254;
  else if ( (  127 - drive_ly + drive_lx ) < 0 )
    motor_fr_1 = 0;
  else motor_fr_1 =  127 - drive_ly + drive_lx;
  if ( ( 382 - drive_ly - drive_lx ) > 254 )
    motor_br_1 = 254;
  else if ( (  382 - drive_ly - drive_lx ) < 0 )
    motor_br_1 = 0;
  else motor_br_1 =  382 - drive_ly - drive_lx;
  if ( ( 127 + drive_ly - drive_lx ) > 254 )
    motor_bl_1 = 254;
  else if ( (  127 + drive_ly - drive_lx ) < 0 )
    motor_bl_1 = 0;
  else motor_bl_1 =  127 + drive_ly - drive_lx;
  if ( (motor_fl_1 < 137) && ( motor_fl_1 > 117 ) )
    pwm_drive_fl = 127;
  else  pwm_drive_fl = motor_fl_1;
  if ( (motor_fr_1 < 137) && ( motor_fr_1 > 117 ) )
    pwm_drive_fr = 127;
  else  pwm_drive_fr = motor_fr_1;
  if ( (motor_br_1 < 137) && ( motor_br_1 > 117 ) )
    pwm_drive_br = 127;
  else  pwm_drive_br = motor_br_1;
  if ( (motor_bl_1 < 137) && ( motor_bl_1 > 117 ) )
    pwm_drive_bl = 127;
  else  pwm_drive_bl = motor_bl_1;
we're pretty sure its an overflow error, but this code should make up for that.
can anybody help please?
Unread 26-01-2008, 17:09
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: 2008 Omni Drive Code Help
Anytime you add two chars together you risk overflow. Try making all your variables ints. Overflow is still possible, but only when you're working with numbers a lot larger than joystick and motor values.
Unread 26-01-2008, 22:11
yea that was our first idea too.
we made everything signed ints in order to avoid this issue. but somehow when we tried to limit mix them into the 0-254 range, the limit mix failed or something.
but no matter what happened it still didnt work.
could it be that we never casted them back into unsigned chars before assigning them to the pwm? because when i tried that we got pure 254 for all four outputs.
thanks for the help by the way. much appreciated.
Unread 26-01-2008, 22:39
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Rookie Year: 1997
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
First uses this:
pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
They Add 2000 to prevent a negative value and when they call LIMIT_MIX ()
It evaluates the result and subtract out the 2000. I think your code could be changed to
motor_fl_1 = Limit_Mix(2000 + drive_ly + drive_lx - 127);
motor_fr_1 = Limit_Mix(2000 + 127 - drive_ly + drive_lx);
motor_br_1 = Limit_Mix(2000 + 382 - drive_ly - drive_lx);
motor_bl_1 = Limit_Mix(2000+ 127 + drive_ly - drive_lx);
pwm_drive_fl = 127;
pwm_drive_fr = 127;
pwm_drive_br = 127;
pwm_drive_bl = 127;
This should prevent any over runs even if your joystick is doing something weird. Are you using a chicket?
Although I must admit I don't understand the "382 - drive_ly - drive_lx" but I'll assume you know the formula to be correct and that the problem you're having is from a violation in a positive integer math problem.
Hope that helps
Steve
Unread 26-01-2008, 22:57
thanks for that code. and yes we are using a chicklet to enable us to use an xbox 360 controller. does that make a difference?
and we tried using the default limit mixes, they cased the same problem, which is why i wrote my own up in that code. we suspected that somewhere there was a datatype conversion that messed us up, so we tried to eliminate all of them.
Unread 27-01-2008, 00:57
Rookie Year: 1997
Chicklet can give weird outputs if the calibration is off or if the battery goes low.
I had that problem once and have made sure the battery we use is fully charged whenever we use it.
Try using one of the joysticks as a test to see if the problem occurred in the code or just when the Chicklet and Xbox controller is being used. Since you are having the problem occur with default code and the Chicklet/Xbox, that's almost certainly the problem. Default is pretty solid. If the numbers are inverting in default code with that 250 to 4 flip, it's probably happening because the system is getting that information in to begin with.
Good luck
Steve
Need help in Kevin's 2008 default code robotrobot2 Programming 5 20-01-2008 14:36
Lego Omni Drive Synergy1848 Robot Showcase 19 03-01-2007 11:51
pic: vex omni drive 1902_Battery_SGT FIRST Tech Challenge 6 28-05-2006 17:55
omni drive vs tank |20807 61|2|_ Technical Discussion 49 17-01-2006 13:54
Omni-drive autonomous questions Andrew Schuetze Programming 6 17-01-2006 12:15
