Go to Post You can never go wrong by gaining height by way of a Segway. - Elgin Clock [more]
Unread 26-01-2008, 19:51
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Is this a real torsion spring?
Hi guys,
I am trying to figure out if my calculations are correct.
would a torsion spring which produces 173 pounds/rotation and is pulled to 180 degrees be something that is realistic?
I can't figure out how to convert the ft-lbs over at mcmaster to lbs/rotation....
am I even working in the right units? somehow lbs/rotation seems to be what I want, and I can't understand what ft-lbs do here... (it's late... give me a break )
Thanks!
-Leav
p.s.
phew! CD just had a database error! I need to get my heart back up from my pants!
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Last edited by Leav : 27-01-2008 at 00:54. Reason: spelling (it's torsion, not "tortion")
Unread 26-01-2008, 20:03
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Rookie Year: 2007
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: Is this a real tortion spring?
Torsion springs produce torque so pounds per rotation is not a unit which can be applied to them. What the unit on McMaster car is referring to is the maximum torque when the spring is fully wound. It should have a linear decay from that point.
So for a 180 degree spring with 40in lbs of torque it would have 20in-lbs at 90 degrees and 0 in-lbs at 0 degrees.
I'm not sure if you know this so I also give a brief explanation of torque.
Essentially 1 ft-lb can support 1 lb on a one ft radius. so a 40 in-lb spring would be able to just barely support a 40lb load at 1 in from the point of rotation.
To figure out how much torque you need to produce a given speed you will have to used rotational physics equations such as torque=rotational acceleration*moment of inertia.
Last edited by Matt H. : 27-01-2008 at 00:05. Reason: A mistyped number which might have caused great confusion
Unread 26-01-2008, 22:25
DonRotolo's Avatar
Back to humble
FRC #0832
[quote=Matt H.;686342] so a 40 in-lb spring would be able to just barely support a 40lb load at 4in from the point of rotation.
QUOTE]You mean a 40 lb load at 1 inch (or 10 lb at 4 inches). 40 lb at 4 inches is 160 in-lbs.
Torque in ft-lbs is exactly what it sounds like - a force of one pound at 1 foot from the center of rotation.
If you pushed with the same force at 2 feet from the CoR, you'd have 2 ft-lb, and you know that makes sense from when you use a wrench to tighten a bolt - a longer wrench puts more force on the bolt with the same push.
If you decided that 20 pounds would push a ball to a certain height, and your torsion spring was 40 ft-lb at 180 degrees of wind-up, then an arm two feet long would push with 20 pounds (for the first instant). As the spring unwinds, the force decreases linearly to zero at no rotation.
Does that make sense??
Unread 27-01-2008, 00:53
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
thanks guys...
so my calculations show that I need 173 inch-lbs.
which is about 4.5 more than what mcmaster carries.... I hope the local spring shop has what we need... thanks!
-Leav
-Paraphrasing JFK
Unread 27-01-2008, 01:03
Rookie Year: 2007
You could also try and solve that by using several springs together.
pic: This is a Real 1147 Meal. billbo911 Chit-Chat 8 22-01-2007 14:54
Real Names, Real Faces The Lucas General Forum 37 23-04-2006 18:33
How about a REAL teaser? This one will keep you guessing... Travis Covington Robot Showcase 17 11-02-2006 12:03
Does this look real enough? TheFork 3D Animation and Competition 6 08-03-2003 00:19
What's real, What's better than real... Excelsior12 3D Animation and Competition 26 17-02-2003 20:50
