Go to Post Your entire life is a choice - a choice to believe or denounce everything that is ever said to you. - Amanda Morrison [more]
Unread 26-01-2008, 20:42
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
1726 Prototype Testing
Here's a short video of our prototype mechanisms in use.
http://www.youtube.com/watch?v=LDvo2uY7dcU
You can also see some picture going up at:
http://photos.project1726.org
Comments, questions, suggestions appreciated!
Unread 26-01-2008, 20:47
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: 1726 Prototype Testing
very nice, it goes up really high
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 26-01-2008, 20:51
Unregistered User
AKA: Kevin Forbes
It goes a little higher when you hold it down (like it will once the last component is finished)
http://www.youtube.com/watch?v=G9y-LhHRAHw
Unread 26-01-2008, 21:33
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
oh man that catapult is BEAST
what did you use to power the catapult?
I cant really tell, but is ure robot within the 28 by 38 requirement ?
Unread 26-01-2008, 21:42
DonRotolo's Avatar
Back to humble
FRC #0832
Best one I have see so far! That's great!
Unread 26-01-2008, 21:47
Unregistered User
AKA: Kevin Forbes
I wasn't working on that component, but I think we have 2 2" bore 10" stroke pneumatic pistons. We did a 'trick' (well known, I think) by keeping the cylinder from moving at 60psi with 3in. filled. Then we release the ball, and the air stored in the 1/3rd of the cylinder expands very quickly, giving us enough force to launch the ball.
Right now we're working on lowering the air consumption (right now a single shot drops our pressure from 115psi to about 80psi...)
And yes, I believe it is within the limits... However, this is a culmination of 2 prototypes, a mechanism mounting bracket, and last year's robot. The real thing will (hopefully) be much nicer
Unread 26-01-2008, 21:52
neoshaakti's Avatar
what do you mean by keeping the cylinder from moving at 60 psi with 3 in filled?
sorry Im a nub
Unread 26-01-2008, 21:57
Unregistered User
AKA: Kevin Forbes
basically when the catapult is fully retracted, the cylinder sticks out 3 in. Before we shoot, we hold down the ball (from the top, we still have to make that part) and open the valve. Air from the tanks fills up that 3in. and we wait until it is time to fire. When we fire, we remove the top piece and the air inside the cylinders expands rapidly, launching the ball.
Maybe I should make a quick diagram...
Unread 26-01-2008, 21:59
neoshaakti's Avatar
so your bore starts 3 inches, and it fires out to 10? so basically you're using the potential energy of the bore that is protruding 3 inches?
yeah a diagram might help...
Unread 26-01-2008, 22:11
MrJebus MrJebus is offline
FRC #1726
MrJebus is an unknown quantity at this point
Think of it like a spring, but instead of energy being stored in the coils, its stored in the cylinder with the air. Only reason that it sticks out 3in is so the pressure can build, storing the energy.
Unread 26-01-2008, 22:19
Unregistered User
AKA: Kevin Forbes
Exactly!
Here's a diagram (out of proportion and not quite right, but what the hay):
Unread 26-01-2008, 22:42
neoshaakti's Avatar
Exactly!
Oh that is pretty cool
do u have to program the bore to protrude 3 " out, or do u mechanically set block it from full retracting (Im guessing the 2nd...programming a bore doesnt seem probable)
haha
Unread 26-01-2008, 23:38
=Martin=Taylor= =Martin=Taylor= is offline
run the trap!!!
FRC #0100 (The Wild Hat Society)
Team Role: Human Player
=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute=Martin=Taylor= has a reputation beyond repute
Are you at all worried about running out of air?
I think you might hurdle too fast ( ) and drain your tanks.
"Cooperation; because life is a team sport"
-Philip J. Fry
Unread 27-01-2008, 17:05
falconmaster's Avatar
Happy Birthday! falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
Team Role: Teacher
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
haha
You guys are awesome! Great Job! Great idea!!!
Faridodin "Fredi" Lajvardi KD7WKD
  #15   Spotlight this post!
Unread 27-01-2008, 22:58
jhaugen jhaugen is offline
J. Haugen
FRC #0842 (Carl Hayden Falcons)
jhaugen is an unknown quantity at this point
That's outrageous. Looks great.
pic: FRC 1726 Steering Prototype MrForbes Extra Discussion 15 12-01-2008 21:21
pic: 1726 Promobot GUI Extra Discussion 18 01-11-2007 18:04
pic: 1726 Demo Bot s_forbes Extra Discussion 6 27-06-2007 12:56
pic: 1726 Ramp Progress s_forbes Extra Discussion 6 19-02-2007 01:14
pic: 1726 2007 OI TheOtherGuy Extra Discussion 2 11-02-2007 23:17
