Global variable question
If I create a global variable in one .c file, can I access this variable from another .c file?
I thought so, but I get the error "symbol 'varname' has not been defined." Thanks, Nathan |
Re: Global variable question
In one file, define it like this:
Code:
int foo; Code:
extern int foo; |
Great, thanks!
Nathan |
A simple way to make sure this works in all files is to add this to a header (.h) file:
Code:
#ifdef DEFINE_VARS extern int foo; #endif #ifndef DEFINE_VARS #define DEFINE_VARS int foo; #endif I hope this helps. |
| Global Variable Placement | robbrad | Programming | 1 | 23-01-2008 00:50 |
| Stupid Variable question.... | BillyJ | Programming | 3 | 20-02-2006 19:49 |
| Beginning programmer: Variable question HELP!!! | Calvin | Programming | 4 | 03-02-2006 18:12 |
| Camera variable scope question | Validius | Programming | 1 | 28-01-2006 09:24 |
